Author: Subject: megajolt trigger wheel...
boggle
posted on 30/3/10 at 10:32 AM Reply With Quote
just looking at my megajolt triiger wheel....
does anyone know what bore size i need for a pinto and is there a keyway needed??
cheers
barry
u2u me for details
Hugh_
posted on 30/3/10 at 10:59 AM Reply With Quote
It's a year or so since I fitted mine, but from memory no keyway and I'd guess at M12, maybe M14.
boggle
posted on 30/3/10 at 11:06 AM Reply With Quote
thanks
will cut one of each...
u2u me for details
boggle
posted on 30/3/10 at 12:15 PM Reply With Quote
another stupid question...
2mm steel????
u2u me for details
cd.thomson
posted on 30/3/10 at 12:19 PM Reply With Quote
more like 5mm, you dont want the teeth vibrating at all.
Craig
blakep82
posted on 30/3/10 at 12:50 PM Reply With Quote
5mm at least. 2mm will be too wobbly, and too thin to give you a decent signal
better if you can cover the whole end of the sensor
[Edited on 30/3/10 by blakep82]
________________________
boggle
posted on 30/3/10 at 01:34 PM Reply With Quote
well i can go up to 300mm......
u2u me for details
Miks15
posted on 30/3/10 at 01:50 PM Reply With Quote
might be a bit overkill, 250 should stop the wobble
Thinking about it
posted on 30/3/10 at 02:01 PM Reply With Quote
That will double up as a flywheel
blakep82
posted on 30/3/10 at 02:35 PM Reply With Quote
mines 5mm i think. works well
well, as far as i can tell, considering my wirings not done, and the sensor wasn't lined up properly
boggle
posted on 30/3/10 at 02:43 PM Reply With Quote
does it have to be mild steel??? not ali??
is it because the sensor works on a magnetic field???
u2u me for details
blakep82
posted on 30/3/10 at 02:59 PM Reply With Quote
must be steel. ali won't work. the inside of the sensor is a little magnet
