Author: Subject: ZX9R throttle sensor colours?
FASTdan
posted on 31/3/10 at 07:28 AM Reply With Quote
We are just in the process of wiring our megajolt, can anyone advise what colours are what on the ZX9R TPS? I believe the functions are ground, live feed and output signal?
Colours we have are yellow blue and black........
flak monkey
posted on 31/3/10 at 07:30 AM Reply With Quote
To hook up your throttle position sensor (TPS), disconnect the TPS, and use a digital multi-meter. Switch it to measure resistance. The resistance between two of the connections will stay the same when the throttle is moved. Find those two - one will be the +5 Vref and the other a ground. The third is the sense wire to the MegaSquirt® controller. To figure out which wire is the +5 Vref and which is the ground, connect your meter to one of those two connections and the other to the TPS sense connection.
Sera
http://www.motosera.com
cd.thomson
posted on 31/3/10 at 07:58 AM Reply With Quote
just do what I did and randomly connect the wires together until you get a sensible reading on the megajolt
Craig
Rob Allison
posted on 31/3/10 at 11:58 AM Reply With Quote
Lol proper diy.
