Author: Subject: Vacuum Dizzy Or Non Vacuum Dizzy
Barksavon
posted on 31/3/10 at 02:40 PM Reply With Quote
Does connecting the distributor vacuum tube to the outlet tube on a twin choke dellorto carburettor (two carbs to be fitted) affect the operation of the carburettor/engine in a similar way that connecting the crank case breather to the inlet manifold union mucks up the running of the cylinder that its drawing the vacuum from.Will i be better off getting hold of a non vacuum advance dizzy, its electronic ignition
cadebytiger
posted on 31/3/10 at 02:53 PM Reply With Quote
I don't think the vacuum is great enough from a single choke of twin webbers/dels
better off with a non-vac-advance dizzy
