Author: Subject: Zetec Spark Map
prelude1980
posted on 8/4/10 at 08:34 PM Reply With Quote
Zetec Spark Map
i was just wondering if anybody has a zetec spark map i could start off with.
My set-up is a 2 litre blacktop with gsxr 600 throttlebodies.
Forgot to say Megasquirt 2 v3
[Edited on 8/4/10 by prelude1980]
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
big_wasa
posted on 8/4/10 at 08:43 PM Reply With Quote
I have grabed this from the net as my base map on my dta e48exp.
its running.
t16turbotone
posted on 9/4/10 at 06:02 AM Reply With Quote
http://www.extraefi.co.uk/downloads.htm
atspeed racing
posted on 9/4/10 at 12:56 PM Reply With Quote
what software are you using?
i could write you a base ignition map.
- colin.
prelude1980
posted on 9/4/10 at 05:10 PM Reply With Quote
i tried extraefi.co.uk but the maps they had on the didn't seem to have spark maps
gets you.
prelude1980
posted on 9/4/10 at 05:11 PM Reply With Quote
- colin.
I'm using MS2 V3 Firmware V2.891 on tunerstudio
gets you.
atspeed racing
posted on 10/4/10 at 09:48 AM Reply With Quote
i have just written a basic ignition map for you to copy. this should point you in rough direction for most NA engines, certainly be good enough to drive the car to a rolling road
most important thing is to confirm your crank sensor is positioned correctly in relation to TDC. i have seen many engines destroyed due to this being incorrect (even by "professional" tuners) check this with a timing light, remember for wasted spark systems, the number may be double on the timing light. example: 20=10degrees. and always check on live timing rather than just the ignition map, as this will also take into account for any additonal ignition or retards for air temps, coolant temps, barometric pressures etc.
- colin
prelude1980
posted on 10/4/10 at 12:48 PM Reply With Quote
brilliant thanks i'll give that a go
gets you.
