norfolkluego
| posted on 8/4/10 at 09:02 PM |
Zetec sump bolts
Anyone know what size they are, I've got a couple that look decidedly second hand and need replacing
Mal
| posted on 8/4/10 at 09:23 PM |
The Zetec silvertops use M8 flanged bolts with 10mm hexagons rather than the 13mm ones on standard bolts.
norfolkluego
| posted on 8/4/10 at 10:00 PM |
This is a 1.8 blacktop and they're definitely smaller than M8, haven't got any M6s in the garage to try but I get a feeling they could be
smaller than that
r1_pete
| posted on 9/4/10 at 07:37 AM |
As above, my blackie was M8 with 10mm flanged heads, thats the ally bit to the engine. I think the tin to ally screws are M6 with 8mm heads.
If you'd posted this last week I could have sent you a set, binned a load of old stuff over the holiday weekend.....
norfolkluego
| posted on 9/4/10 at 11:28 AM |
Sorry, should have made it plain, what I was on about it is the bottom part of the sump (the bit with the drain plug), so M6 sounds about right
