Author: Subject: How close is too close
norfolkluego
posted on 9/4/10 at 09:42 PM Reply With Quote
My carb trumpets, now with filter sicks on, are very close to the inside of the bonnet carb one is more or less touching it. Question is being so close will they struggle to breath enough air, not sure whether to leave them as they are or cut a hole in the bonnet to let them breath better. What do you guys think is best?
[Edited on 9/4/10 by norfolkluego]
omega0684
posted on 9/4/10 at 09:59 PM Reply With Quote
cut a hole, not only will air flow be restricted but it will be horrible hot air getting sucked in too!
austin man
posted on 9/4/10 at 11:02 PM Reply With Quote
I think you answered your own question
atspeed racing
posted on 10/4/10 at 10:04 AM Reply With Quote
as a general rule;
the absolute minimum clearance between a trumpet and airbox(or bulkhead) is 30% of its total outside diameter (including radius part)
example:
50mm trumpet = 15mm minimum clearance.
- colin.
bi22le
posted on 10/4/10 at 10:05 AM Reply With Quote
spend your time on doing a nice but in the bonnet. Engines only need three things to work and you may be robbing yours of one of the most important ones.
Please read my ring story:
posted on 10/4/10 at 01:50 PM Reply With Quote
Sock filters do this all by themselves!
smart51
posted on 10/4/10 at 01:55 PM Reply With Quote
you need 1 choke diameter's distance from the mouth of the trumpet to the nearest solid object as a minimum.
posted on 10/4/10 at 06:43 PM Reply With Quote
You really don't; the majority of the air entering a trumpet comes in at an angle from the side, so even having a flat plate to up 1/3 choke diameter away barely affects flow. It would affect pulse tuning however.
