Toprivetguns
| posted on 11/4/10 at 08:05 PM |
ZX10R fuel pump issue
Basically without going into too much detail my fuel pump won't prime upon me switching on the ignition. Ive tested all concerned wires for
continuity etc and found out my white/red wire is not producing any voltage. So I turned to the good book (Kawasaki Manual) and troubleshot the fuel
pump relay.
Low and behold the relay failed. So in turn before I buy a new item has anyone else experienced this? Is there something I am missing?
Everything else is functional as per the book and there is no ''FI'' light present.
Ideas greatly appreciated.
Only drive as fast as your angel can fly... !
RichardK
| posted on 11/4/10 at 08:38 PM |
Has it got a tilt switch that could be wonky (technical term)
Rich
Gallery updated 11/01/2011
Toprivetguns
| posted on 12/4/10 at 07:48 PM |
Tilt switch is in the correct position. Cheers though
