Davey D
| posted on 12/4/10 at 07:25 AM |
Fitting Oil Gauges
Im going to be fitting my Oil Pressure, and Temp gauges to my 2006 5vy R1 engine, and im wondering what is the best/easiest way to do it?
Should it get a sandwich plate, or drill/tap the sump?
imp paul
| posted on 12/4/10 at 07:42 AM |
spire sports drill/tap the sump to do this job but i don't see why you could not buy a sandwich plate as you say all the best paul
turbodisplay
| posted on 12/4/10 at 07:45 AM |
I think you can get sandwich plates that do both pressure and temp sensor, might make sense to do both at the same time.
Darren
adithorp
| posted on 12/4/10 at 09:58 AM |
Yamaha test oil presure from the oil gallery and thats where I've got mine. There's an M16 plug with (allen key) on each end of the block.
Same plug each end so you can't miss them. Take your pick which one suits you best and just replace the plug with an adapter.
You can get a maual here.
http://yzf-r1forum.net/manuals/index.html
Durite do an adapter set (Pt no 0-523-98) with the right thread and I think Europa also stock something.
adrian
http://jpsc.org.uk/forum/
will121
| posted on 12/4/10 at 11:22 AM |
dont know speciffically about the R1, but you can get universal sump drain plugs with a 1/8" BSP tapping in the middle to fit a temperature
sensor
lsdweb
| posted on 12/4/10 at 11:35 AM |
I drilled and tapped the sump for the temperature and the oil gallery blank for the pressure
  Oil Pressure Fitting - 5VY
Davey D
| posted on 12/4/10 at 12:15 PM |
aah thats just what ive got in mind. i was planning on redrilling/tapping that hole in the sump.
im going to a durite dealer tonight on my way home for some electrical bits, so ill see if theyve got the adapters in stock.
where did you get your braided takeoff hose? are you using it to stop the vibrations from damaging the bigger sensor the pressure gauges have?
lsdweb
| posted on 12/4/10 at 12:29 PM |
The braided hose and all the adaptors came from Think Auto.
The oil pressure sensor was mounted in a big rubber lined alloy clip to protect it from vibration.
