<<  1    2  >>
Author: Subject: Help Needed - Cylinderhead
prelude1980
posted on 13/4/10 at 11:30 AM Reply With Quote
i have 2l blacktop zetec, i'm trying to tune it on megasquirt. but when you look down the inlet on cylinder 2 when the engine is running you can see it light up, i've tried adjusting the spark table up and down but with no effect other than make the engine run rougher than it is.
any help much appreciated
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
cd.thomson
posted on 13/4/10 at 11:32 AM Reply With Quote
incorrect cam timing or you have the HT leads mixed up?
Craig
prelude1980
posted on 13/4/10 at 11:37 AM Reply With Quote
i've checked the timing and it's right to megasquirt. ah with the leads i think i have. is there a diagram showing the correct way?
gets you.
prelude1980
posted on 13/4/10 at 11:42 AM Reply With Quote
just checked and the leads are on correct.
gets you.
cd.thomson
posted on 13/4/10 at 11:45 AM Reply With Quote
no, incorrect cam timing not spark timing. Is there any possibility the cambelt has slipped or that the cams could have been fitted incorrectly?
Also the inlet valve could be sticking open, has any work been carried out on the engine?
Craig
posted on 13/4/10 at 11:52 AM Reply With Quote
Weak mixture will cause this, partially blocked injector perhaps?
Fatgadget
posted on 13/4/10 at 11:57 AM Reply With Quote
Not timing surely..otherwise ALL ciylinders would exhibit the same symptoms no?
My prognosis given the symptoms is either a duff injector or manky spark plug...swap them around and c the outcome.
prelude1980
posted on 13/4/10 at 12:11 PM Reply With Quote
I've had the plugs out and they are all good and clean with the same gaps. i'll try swapping the injectors around.
gets you.
prelude1980
posted on 13/4/10 at 12:12 PM Reply With Quote
sorry i misunderstood. the cams seem correct, the head has been smoothed out a bit and the inlet port matched to the inlet manifold
gets you.
prelude1980
posted on 13/4/10 at 12:39 PM Reply With Quote
i just swapped the injector over with another cylinder but it's still doing the same thing
gets you.
atspeed racing
posted on 13/4/10 at 12:48 PM Reply With Quote
Do a compression test
prelude1980
posted on 13/4/10 at 01:01 PM Reply With Quote
i'll have to go get a tester for that. but assuming that test comes back ok. what's next.
if the test comes back and the pressure is low, is that piston rings?
gets you.
Mal
posted on 13/4/10 at 01:30 PM Reply With Quote
Is this the first time of running the engine since wiring it for Megasquirt?
If so you may have the wiring for cylinders 1&3, then 2&4 incorrect in relation to the coil pack connections.
Mal
posted on 13/4/10 at 01:32 PM Reply With Quote
Correction to the above post
If so you may have the wiring for the injectors to cylinders 1&3, then 2&4 incorrect in relation to the coil pack connections.
prelude1980
posted on 13/4/10 at 01:38 PM Reply With Quote
no this isn't he first time the car has been run, i've just upgraded the inlet side from a diy manifold to a st170 one, although i'm starting from scratch on the tuning
gets you.
prelude1980
posted on 13/4/10 at 01:39 PM Reply With Quote
also i'm using simultaneous firing so that shouldn't matter
gets you.
prelude1980
posted on 13/4/10 at 03:14 PM Reply With Quote
just a small update been messing with the car more, the throttlebodies aren't balanced and adjusting them is helping although the balancer i got is crap so need to get another one
gets you.
Chippy
posted on 13/4/10 at 04:17 PM Reply With Quote
Sounds to me like either a sticking inlet valve, or the tappet have been wrongly adjusted holding the valve open just a tad. Does the Black top have hydraulic lifters, if so then that one in over pumping. My opinion, for what it's worth! Cheers Ray
prelude1980
posted on 13/4/10 at 04:20 PM Reply With Quote
It has solid lifters, how would you fix a sticking valve?
gets you.
MakeEverything
posted on 13/4/10 at 05:48 PM Reply With Quote
^^ What he said ^^
If you can "See" into the cylinder, then the valve is open! It should be closed. Either that or you have a seriously hot inlet valve, and some worrying detonation going on.
Kindest Regards,
Richard.
MakeEverything
posted on 13/4/10 at 05:55 PM Reply With Quote
^^ What he said ^^
Or the overlap on that cam for that cylinder is incorrect, but you say you havent changed it?
Kindest Regards,
Richard.
prelude1980
posted on 13/4/10 at 05:57 PM Reply With Quote
^^ What he said ^^
mmm well i'm looking at the throttlebodies when they are closed and can see it light up behind, but after playing with balancing it has gone. so i'm hoping that's what it is, just bought a carbtune so will tune properly and see what happens.
Usually something simple and my inexperience showing
[Edited on 13/4/10 by prelude1980]
gets you.
MakeEverything
posted on 14/4/10 at 07:16 AM Reply With Quote
Dont dismiss it though.
The carbs will have a vacuum to lift the gizmo inside. ideally, i think id be taking the head off to have a proper look, but i know that takes time, effort and money!
Kindest Regards,
Richard.
posted on 14/4/10 at 08:54 PM Reply With Quote
No need to take the head off to check for burnt/sticking valves! Do a cylinder leakage test and check/adjust the valve clearances
prelude1980
posted on 14/4/10 at 08:59 PM Reply With Quote
well if it still acts odd after i've played with the balancing and fuel/spark. i'm gonna start looking at removing the head or checking for a sticky valve, really not keen on that just yet. but thanks for the suggestions, this weekend will soon tell what i need to do..
Fingers crossed
gets you.
<<  1    2  >>
