Author: Subject: Injection pump and filter connection help
adrianreeve
posted on 19/4/10 at 08:15 PM Reply With Quote
My bosch fuel injection pump has a 10mm inlet, and my tank has a 10mm outlet, but all of the high pressure filters a can find cheaply are 8mm in and out. This means I'll have to get adaptors on both sides of the filter, which seems a bit silly! Does anyone havea source of cheap filters with 10mm tails please?
Adrian
adithorp
posted on 19/4/10 at 08:34 PM Reply With Quote
The (high presure) filter should go after the pump, ie. on the high presure side.
On the inlet side just put a low presure plastic filter, altough this will restrict flow to the pump. Tin-tops just have a gauze on the pick-up pipe to keep stuff from getting to the pump.
adrian
http://jpsc.org.uk/forum/
turbodisplay
posted on 19/4/10 at 09:19 PM Reply With Quote
I used a facet pump to feed the swirl pot, facets have a fine filter inbuilt the pump.
Darren
cliftyhanger
posted on 20/4/10 at 05:53 AM Reply With Quote
http://cgi.ebay.co.uk/SYTEC-CLEAR-FUEL-FILTER-CARBURETTOR-GLASS-pro806-10mm_W0QQitemZ270471057954QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM? hash=item3ef954d222
http://cgi.ebay.co.uk/Fuel-Filter-For-10mm-intake-outlet-pipe-CHINESE-QUADS_W0QQitemZ250617760856QQcmdZViewItemQQptZUK_CartsParts_Vehicles_ATVQuad_Tri ke_Parts_Accessories_SM?hash=item3a59fb8c58
adrianreeve
posted on 20/4/10 at 07:44 AM Reply With Quote
Doh!
Brain fade moment, thanks for clarifying adithorp!
Adrian
adithorp
posted on 20/4/10 at 11:18 AM Reply With Quote
I tried to say it a in the nicest way I could
adrian
