jossey
| posted on 20/4/10 at 02:58 PM |
Engine..... Motorbike or CAR
im currently looking at options for an engine. with sierra's now being very few im looking at other options. one of which a zzr1100
motorbike.
i have some transmission gear.
a LSD which shafts fitted to my car and a prop for a type 9 gearbox.
Any suggestions what i can do without breaking the bank.
cheers.
[Edited on 20/4/10 by jossey]
David Johnson
Guinness
| posted on 20/4/10 at 03:10 PM |
Bung the big old zed in there.
Basically you'll need the original propshaft shortening / additional UJ putting in. MK can do this for you. Then a sproket adaptor.
If you have the whole bike, then use the ignition unit, coils, loom, fuse box, fuel pump, carbs, oil cooler and engine itself.
Depending on your install, you may need to chop the sump, or install a GPZ900 one (same bolt patten, just 75mm shallower!).
Mike
boggle
| posted on 20/4/10 at 03:12 PM |
and you will need an engine cradle and you may need to restrengthen your chassis if you have to chop it to fit the engine...
u2u me for details
jossey
| posted on 20/4/10 at 03:17 PM |
thanxxx
thanks for that. ill keep the zzr 1100 then.
Thanks all.
David Johnson
FFTS
| posted on 20/4/10 at 03:44 PM |
SO!! Which is best?? BEC or CEC
Chris.
philw
| posted on 20/4/10 at 03:50 PM |
Who cares
Must try harder
iank
| posted on 20/4/10 at 03:55 PM |
The answer is obvious, they both are.
Anonymous
prawnabie
| posted on 20/4/10 at 03:57 PM |
Think about what you want to use the car for as this may dictate your engine choice.
jossey
| posted on 20/4/10 at 04:02 PM |
car use.
more than likely as a trial to build a light weight version. so maybe sva it and then use on track days.
so everything.
David Johnson
speedyxjs
| posted on 20/4/10 at 05:43 PM |
Despite my strong opinion, if its going to be lightweight and mainly track use, the best engine would be a... a... DAMN cant say it
Bike engine
jossey
| posted on 20/4/10 at 06:12 PM |
speedy.....
im sorry if the last post hurt. but i know. im a believer in the (no replacement for displacement) but when you have a lightweight chassis and parts.
its worth going the bike way.
if it was my choice and not weight then i would get the V6 or V8 engine stuck in.
David Johnson
