alistairolsen
| posted on 20/4/10 at 03:11 PM |
4 speed to 5 speed, Type 2,3,4 and 9 boxes....
If one had a car with a type 2 or 3 four speed gearbox, and one removed it and fitted a type 9, would the existing prop shaft, gear selector hole and
engine mounts be suitable?
I know there is a bulge in the alloy end casing for 5th gear, but beyond that is the external architecture the same?
My Build Thread
lewis
| posted on 20/4/10 at 03:46 PM |
Dose burton's website give dimentions on all tha boxes?they have pics on there so might help abit?
prawnabie
| posted on 20/4/10 at 03:53 PM |
The type 9 is much bigger in length and width so the propshaft will need shortening and the splined end changing.
The bellhousing is also larger where the fork exits - the fork all exits at a different angle.
The mounting will need to be repositioned much further back as will the hole for the selector.
[Edited on 20/4/10 by prawnabie]
snapper
| posted on 20/4/10 at 06:01 PM |
Type 2&3boxes also had 7/8th x 20 spline input shafts the Type 9 has 1" x 23
I eat to survive
I drink to forget
stevebubs
| posted on 20/4/10 at 08:18 PM |
The consensus is "no"
alistairolsen
| posted on 20/4/10 at 09:27 PM |
Hmm, so any 4 speed car that Id like to upgrade to 5 speed is going to need extensive work....
My Build Thread
| posted on 21/4/10 at 11:58 AM |
No...if the 4 speed is the "Type E" (as described on Burtons web page), then the only change required for a Type 9 is moving the gearbox
mounting and possibly the gear lever hole in your tunnel. The overall length is the same so the prop will fit.
However, not all people would consider a standard Type 9 an "upgrade" in this case! The 4 speeder has pretty decent ratios but the Type 9
has an almost unusable first gear in a light car.
[Edited on 21/4/10 by MikeRJ]
