alistairolsen
| posted on 21/4/10 at 08:54 AM |
Turbo oil drain
I need to knock up a turbo oil drain from a normal mitsibishi style flange to some form of sump fitting.
My inital thought was to get a threaded fitting with a hose tail for the sump and then run a piece of hose and two crimps but what spec of hose?
The other alternative is to try and modify some OE return pipe by cutting and welding it?
I notice most OE manufacturers use a hard steel pipe, how would one protect a rubber one against the heat from the turbine housing?
My Build Thread
t16turbotone
| posted on 21/4/10 at 08:59 AM |
i used threaded fittings with hose tails and samco silicone hose, its been fine so far!
alistairolsen
| posted on 21/4/10 at 09:18 AM |
Thats good to know! what sort of fall would you recommend from the turbo flange to the sump fitting?
My Build Thread
t16turbotone
| posted on 21/4/10 at 09:29 AM |
On mine there is a 100mm fall, sump fitting must be above oil level in sump, use large drain hose (19mm) because of oil froffing.
| posted on 21/4/10 at 11:51 AM |
You might want to check that, constant immersion in hot oil will cause standard silicone hose to swell up. Flouro-lined hose would be a better bet
here.
Normal oil cooler hose will work, but the very high temperature of the oil leaving the turbo will limit it's life.
I wish the one in my car (Fiat Coupe) was above the oil level, I discovered it wasn't when I removed the turbo...
[Edited on 21/4/10 by MikeRJ]
