Author: Subject: Custom Exhaust
SeanStone
posted on 25/4/10 at 09:04 PM Reply With Quote
Custom Exhaust
How much should I expect to pay for a custom exhaust for my S2000 build?
Are there cheaper ways of going about it or is it always an expensive task?
The first quote I got was £1200.
I won't be running a cat
omega0684
posted on 25/4/10 at 09:06 PM Reply With Quote
if you go to a company that knows about engines and manufacturing of performance exhausts then that figure is not far off,
I had a quote from Simpsons and they wanted nearly £1500!!
Mark G
posted on 25/4/10 at 09:14 PM Reply With Quote
That's well ott. I paid £300 for the exhaust for my Indyblade
mark chandler
posted on 25/4/10 at 09:27 PM Reply With Quote
Must be very very special for that amount, I purchased some stainless bends from Ebay and made mine for £125 !
That aside I would be looking for a pinto or zetec exhaust and modify that to fit depending on what side the car it exists on, should be around 1/4 of that price.
matt_gsxr
posted on 25/4/10 at 09:39 PM Reply With Quote
where are you? I can't see from your profile.
I got a manifold for £400 around here.
Silencer and such is off the shelf item from MK, but you are looking at around £200 for that.
Can you recycle some of the s2000 manifold?
Matt
l0rd
posted on 25/4/10 at 09:42 PM Reply With Quote
i would keep the original headers and fit a custom exhaust from that point onwards.
Some engines are better off without fiddling with them if you don't know how to do it properly.
cd.thomson
posted on 26/4/10 at 08:04 AM Reply With Quote
the s2000 in original form had a very specifically designed exhaust iirc, they are probably intending on recreating the original item as closely as possible within the confines of your car hence the expense.
Craig
SeanStone
posted on 26/4/10 at 03:23 PM Reply With Quote
I do have the manifold which is attached to the downpipe. It weighs a hell of a lot though
dazzx10r
posted on 26/4/10 at 08:22 PM Reply With Quote
Try contacting Martin Keenan
http://www.mkengineering.co.uk/
I was down there today and have seen some really nice 4-2-1 and 4-1 collectors that he has made, I know he can make a custom manifold for £650 and I think his 5" diameter silencers are £200 or £250. Check out my photo archive i've put some pics of Martins work in there.
