nib1980
| posted on 26/4/10 at 07:16 PM |
any tips on how to remove a woodruff key?
Hi All
as the titel says any tips for removing a woodruff key?
many thanks
adithorp
| posted on 26/4/10 at 07:22 PM |
Screw driver against the end and tap should lift it out.
http://jpsc.org.uk/forum/
flak monkey
Normally a tap with a hammer on either end will free them.
Otherwise a small punch under the end and a gentle tap should get it out.
If it doesnt need to come out however, leave it in - you are less likely to lose it!
Sera
http://www.motosera.com
nib1980
| posted on 26/4/10 at 07:29 PM |
do i actually need to take it to get the crank pulley off?
i think it will help.
Danozeman
| posted on 26/4/10 at 07:35 PM |
Nope. You wont get it out with the pulley still on.
You fit it to the crank first then slide the pulley over it to locate it.
[Edited on 26/4/10 by Danozeman]
Dan
tegwin
| posted on 26/4/10 at 07:39 PM |
I have had a few which were stuck seriously solidly...
Heating it with a blow torch and then quenching with penetrating oil a few times loostend it enough to enable me to smack it out with a drift...
needles to say the key was trashed in the process!
www.verticalhorizonsmedia.tv
ReMan
| posted on 26/4/10 at 08:29 PM |
I remember as a youngster just getting into bikes and mopeds of the £2 variety that failed woodruff keys were quite common.
With limited funds, making new ones by cutting and filing a segment out of an Ht bolt was a mfrequent job to repair flywheel-magnetos that had sheared
RazMan
| posted on 26/4/10 at 10:43 PM |
Crank pulleys can be a real biatch to get off the shaft. You will need a GOOD 3 leg puller and some patience. When you eventually get the pulley off,
the woodruff key will probably fall out.
Raz
