goaty
| posted on 6/5/10 at 08:45 AM |
Dry sump hose
Hey,
is anyone able to tell me if you can use the aeroquip push on hoses and fittings on dry sump systems??? or are they not reliable enough???
like these:
http://www.demon-tweeks.co.uk/Motorsport/Oil_System/Oil_Hose_&_Fittings/Push_On_Hose_&_Fittings/Moquip_Steel_45_Degree_Female_Socketless_Hose_
Fitting/1796/3078
cheers
SeanStone
| posted on 6/5/10 at 09:48 AM |
They're all good to use, but I don't think you'll be using push fittings on the pressure side of the pump.
| posted on 6/5/10 at 10:11 AM |
Those fittings are designed to be used on the pressure side, with the correct hose it's rated to 250psi.
SeanStone
| posted on 6/5/10 at 10:13 AM |
I stand corrected!
What are you building?
goaty
| posted on 6/5/10 at 08:53 PM |
sounds good to me then, makes life easier.
Its a supercharged duratec in the making...
SeanStone
| posted on 6/5/10 at 09:03 PM |
What are you planning to do in terms of pump?
I'm looking to get a dry sump pump soon but they're expensive!
Group buy might bring down costs. Best price I've got so far is £430 for a geared pump from titan
[Edited on 6/5/10 by SeanStone]
