adrianreeve
| posted on 6/5/10 at 10:47 AM |
Do you need to replace flywheel bolts?
Do i need to replace the flywheel bolts on my zetec engine when I put the flywheel back on?
Adrian
lotusmadandy
| posted on 6/5/10 at 10:50 AM |
I didn't replace mine and they have been fine.
as far as i know they are a reuseable bolt.
Jasongray5
| posted on 6/5/10 at 11:01 AM |
Im planning to, but only for peice of mind!
How hard can it be?
http://www.flickr.com/photos/33261515@N03/sets/72157611049241239/
| posted on 6/5/10 at 11:03 AM |
Good practice of course.
Worth upgrading to ARP jobbies while its off IMO.
whitestu
| posted on 6/5/10 at 11:06 AM |
I was told by Burtons that the ARP ones are reusable (though at £60 ish a set they ought to be!), and that standard ones aren't.
stu
atspeed racing
| posted on 6/5/10 at 11:14 AM |
depends on the engine and its usage.
any high rpm competition engine - replace with new.
if you can get arp or other uprated bolts, do so.
arp bolts can be re-used.
if its a relatively stock engine - follow manufacturers guidelines.
and always do the bolts up to the correct torque setting.
| posted on 6/5/10 at 11:15 AM |
If they're OEM they may be stretch bolts so no you shouldn't re-use them (even if some people say you can).
Canada EH!
| posted on 6/5/10 at 03:10 PM |
Flywheel and clutch in your lap is not a good site. Years ago a clutch blew in a race Ginetta, the pressure plate lodged in the door, luckily missed
the drivers feet and legs, scared the u no what out of him.
big_wasa
| posted on 6/5/10 at 04:01 PM |
Fly bolts on the ze are not stetch to yeild. New ones do come with a thread lock compound on them. I re-use them with some fresh thread lock on them.
Werner Van Loock
| posted on 6/5/10 at 04:49 PM |
as above, use thread lock on them if reusing
http://www.clubstylus.be
