Author: Subject: Best, ie cheapest, way to get a high ratio Type-9
Steve Lovelock
posted on 9/5/10 at 07:49 PM Reply With Quote
I have a type-9 mated to a Vauxhall Redtop that is getting a little dificult to change down to 2nd. It is also from a P100 so the ratios are too low. So I figure I should try and get a replacement gearbox with higher ratios. However, I am not the nank of England at the moment so need a cost effective way of doing that.
Does anybody know what cars had higher ratio type-9 boxes in as standard? And what is the cheapest way of getting one?
I don't want to spend much time on it either so a swap to an alternative type of box is not a solution.
tul214
posted on 9/5/10 at 07:52 PM Reply With Quote
Only the P100 box had the v.low 1st gear. Just swap it for another capri/sierra box. Pretty cheap on e-bay. Some have even given them away on here.
1.6 Raw Super6 sold
UncleFista
posted on 9/5/10 at 08:15 PM Reply With Quote
The locost way is bigger circumference wheels/tyres
Tony Bond / UncleFista
posted on 9/5/10 at 08:18 PM Reply With Quote
IIRC the P100 may have the longer type bell housing and first motion shaft? Even with the saloon type 9 first is way too low, the v6 box may have better ratios?
skinned knuckles
posted on 9/5/10 at 09:59 PM Reply With Quote
just out of interest, when are you the nank of england and what does the position involve?
A man isn't complete until he's married, then he's finished
snapper
posted on 10/5/10 at 05:42 AM Reply With Quote
Check the length of the input shaft and length of the bell housing when you remove it.
I think it will be standard sierra length, if so then a standard type 9 will bolt straight on and the ratios will be 3.6, 1.97, 1.3, 1 and 0.82.
The V6 box is 3.36, 1.81, 1.2, 1, and 0.82, but it's not a simple fit, either get the input shaft shortened, which needs the box dismantling, or the Caterham spacer that goes between the V6 box and the 4 cylinder bellhousing, this requires the engine moving forward about 30mm.
[Edited on 10/5/10 by snapper]
I eat to survive
I drink to forget
