Author: Subject: that would be why!
deltron63
posted on 12/5/10 at 09:02 PM Reply With Quote
that would be why!
The car has been running a bit rough of late,with a petrol smell coming from the bike carbs. So i thought i'd change the main jets for smaller one's ( old ones were to big), bugger me one jet had fallen out and laying in the float bowl !
Has it happened to anyone else?
iank
posted on 12/5/10 at 09:10 PM Reply With Quote
No, what carb? Could it have been knocked out by a backfire?
Though it has to be said better in the float bowl than in the cylinder
Anonymous
deltron63
posted on 12/5/10 at 09:26 PM Reply With Quote
zx6r carbs. never had a backfire. must be the only thing not locktight, nylocked, welded or glued.
OX
posted on 12/5/10 at 09:45 PM Reply With Quote
It does'nt happen often but it does happen
StevieB
posted on 12/5/10 at 09:52 PM Reply With Quote
I had a drain plug fall out and chuck copious amounts of fuel onto the hot engine (and masses of fuel vapour into Welly's face as he was following me round Langbaugh circuit at the time!).
I just put it down to the vibration and the plug being just a little loose is all. Tightened up correctly and never had a problem again.
greggors84
posted on 12/5/10 at 10:45 PM Reply With Quote
I had a jet vibrate loose and meant the float only went halfway up the bowl so the engine was fine cruising but as soon as you put your foot down or at high revs the fuel was soon used up and the engine would struggle.
Chris
The Magnificent 7!
