Author: Subject: Radiator at the rear of the car...
Dan.
posted on 14/5/10 at 04:20 AM Reply With Quote
As space will be at a premium under the bonnet on my car due to the large engine and dry sump system and intercooler etc to fit in, I have been considering fitting the radiator at the rear of the car and run pipes down the tunnel, has anyone ever done this? any major drawbacks to my plan? I know obviously airflow to rad will need to be considered but I think that could be sorted relativly easily. Would also allow me to run a significantly bigger rad which is preferable, and moves a little bit more weight over the rear wheels... Your thoughts?
nitram38
posted on 14/5/10 at 04:32 AM Reply With Quote
Airflow is your enemy. Strange things happen at the rear of cars like the air turbulence and negative pressure.
Side mounted or ducted would be a better option.
I used to race imps and a rear rad was crap. Front rads were best
speedyxjs
posted on 14/5/10 at 06:08 AM Reply With Quote
How about fitting some ducts in the rear panel at the sides just above the arches to catch the airflow?
Edit - Another option that i was considering was to mount 2 small radiators in the front side panels to catch the air just behind the front wheels.
[Edited on 14-5-10 by speedyxjs]
Dan.
posted on 14/5/10 at 06:11 AM Reply With Quote
First idea was pretty much what I was thinking with the rad mounted flat ish with the cooling fan(s) pulling up
Any other suggestions welcome
[Edited on 14/5/10 by Dan.]
iank
posted on 14/5/10 at 06:27 AM Reply With Quote
Don't worry too much about increasing the rad size (assuming the airflow works) as the long pipes in the tunnel will also act as radiators helping the cause. B&Q sell aerial poles made from aluminium that are long enough and and the right diameter iirc. You may have to think about the water pump though if the existing one isn't man enough.
Overall weight (there's a lot more water in the system) is a downside.
Anonymous
mark chandler
posted on 14/5/10 at 06:32 AM Reply With Quote
It is easy to get air locks, you need to carefully plan the route for success.
I would advise you fit an electric pump to help push the water around, boat bilge pumps are cheap with high volume, no need to spend hundreds here.
Regards Mark
snapper
posted on 14/5/10 at 06:44 AM Reply With Quote
There is a lot you can do before putting the radiator in the back.
Multiple rads, 2 smaller rads one behind the other, extra heater matrix in the engine bay side panels, horizontal rads etc.
You could reduce the passenger foot well and use the space for other engine bay stuff as the passenger foot well does not need to accomodate a pedal box.
I eat to survive
I drink to forget
INDY BIRD
posted on 14/5/10 at 07:25 AM Reply With Quote
if you had to remove 1 from the front i would have the rad at the front and worse case fit intercooler elsewhere ie rear or top mount or charge cooler etc,
Dan.
posted on 14/5/10 at 08:12 AM Reply With Quote
My problem is I am trying to cool 300HP and I think the rad that is on at present would not stand a chance tbh it is substantially smaller than the volvo item.
Top mount for cooler isnt really an option due to engine height, this will be reduced by dry sumping but still remains a tall block. Horrizontal rads are definatly worth considering though.
Good idea about using a bilge pump if I do go down the route of a rear rad.
Benzine
posted on 14/5/10 at 08:23 AM Reply With Quote
I shortened the sump on my 6 cylinder whiteblock, i have a lot more ground clearance than i had with my pinto. I.d go for a custom intercooler/radiator in one that will fit under the nose cone.
mangogrooveworkshop
posted on 14/5/10 at 08:28 AM Reply With Quote
Ran water cooled beetles for a few years and we had a lot of success putting in an oil cooler at the rear but the rad had to be front mounted to stand any chance.
As for cooling the 300 hp engine caterham get a custom triple core rad that fits into the nose. not cheap at 200 od quid.
The long water pipes to move the water round are a pain and they have a problem with clearance.
I used to knock the one hose off regularly when we bottomed out on bumps.
The other thing to remember that having a marginal cooling system is a right pita cause if it does get a bit warmer you have problems on the very days you should be enjoying it.
Dan.
posted on 14/5/10 at 08:46 AM Reply With Quote
Very helpfull, having not compared it to a pinto I just thought it would be taller as people say they are tall blocks. I guess I will be looking into getting a custom rad/intercooler as suggested, thanks.
mangogrooveworkshop
posted on 14/5/10 at 09:07 AM Reply With Quote
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160423427329&ssPageName=STRK:MEWAX:IT
[img]http://cgi.ebay.co.uk/ws/eBayISAPI.dll?VISuperSize&item=160423427329[/img]
posted on 14/5/10 at 11:29 AM Reply With Quote
Are they happy to push coolant at ~90-100C and ~15PSI around for extended periods?
Irony
posted on 14/5/10 at 11:41 AM Reply With Quote
You could always mount the radiator in the rear and then drive around in reverse.
Dan.
posted on 14/5/10 at 12:30 PM Reply With Quote
clearly someone is as sarcastic as i am
Madinventions
posted on 14/5/10 at 12:31 PM Reply With Quote
Dunno if it helps at all, but the engine is in the rear of my Mojo (the correct place) and the rad is at the front. I am using the standard water pump and I have never had any particular problem with airlocks or coolant flow given the extra length the water has to flow. I've used 32mm hoses, both rubber and silicon, and 32mm aluminium tube to extend the flow, and these are run down the tunnel which is quite easy for me as I don't have a propshaft in the way.
For comparison, I'm running 120-130bhp with a standard Polo rad, and the engine sits at 90 degrees all the time now. The water temperature at the exit of the rad is about 60-70 degrees depending on traffic and type of driving so there's a bit of spare capacity for warmer days.
Hope this helps,
Ed.
View my band website:
http://www.shadowlight.org.uk
