Author: Subject: Renault 5 turbo card on a zetec?
rich201283
posted on 15/5/10 at 09:49 PM Reply With Quote
Would a renault 5 turbo carb be sufficient to power a 2ltr zetec turbo?
posted on 15/5/10 at 09:56 PM Reply With Quote
They are very much on the small side for a normally aspirated 2L engine, they have a single 32mm venturi. What size is the original Ford throttle body?
fha772
posted on 15/5/10 at 10:00 PM Reply With Quote
Twin MG Metro Turbo SU's?
http://www.ppcmag.co.uk/forum/viewtopic.php?f=47&t=6743&start=105
hillbillyracer
posted on 15/5/10 at 10:12 PM Reply With Quote
The single HIF 44 (1.75inch) may be enough if you're keen for a carb/turbo set up. I think the MG Turbo Montego used it too & could make 200+bhp on a 2l 8v, how much power do you want to make?
What's the reason for not going for fuel injection? Not saying you should but it's what I'd expect.
skinned knuckles
posted on 15/5/10 at 10:59 PM Reply With Quote
they are barely big enough for the engine they are on. let alone a 2L
A man isn't complete until he's married, then he's finished
rich201283
posted on 16/5/10 at 09:02 AM Reply With Quote
Hi i wouldnt be running stupid ammounts of boost, just think a turbo carb would be easier and less costly.
I thort about a meastro turbo carb but cant seem to find them anymore
skinned knuckles
posted on 16/5/10 at 10:13 AM Reply With Quote
in my earler days of tinkering with cars, i used to do an awful lot with 5turbo's and one of the main things that held them back when they were tuned a bit was the ability of the carb to supply a reasonable amount of fuel higher up in the rev range once the boost had been turned up a bit.
if you are going to use the same carb to fuel a 2L, even at low(ish) boost levels you will start to see problems. and lets face it, you will be tempted to up the boost the other problem with the carb you are looking at is the tendancy for fuel percolation so make doubly certain that you fit a decent perc fan.
we ended up having good results with injection in the end on the 5's and really this would the best alternative for your engine as its far more controllable
rich201283
posted on 16/5/10 at 05:31 PM Reply With Quote
does anyone else know of a carb that would work ok. I have a set of zx9 bike carbs, would these be ok to use?
