Author: Subject: 1600 Pinto Compression
rallyingden
posted on 16/5/10 at 01:58 PM Reply With Quote
My pinto suddenly developed a fault last weekend. It started running on 3 I checked all the leads, which are all new. Still running on points but they are new.
Anyway decided to check compression and got 180psi on all 4, throttle wide open and warm engine.
This figure seems OK to me but not sure what it should be Can anybody tell me what I should expect from a 1600 Pinto.
RD
craig_007
posted on 16/5/10 at 02:01 PM Reply With Quote
No too sure about pinto specfic but I would say that is a good reading.
My Mi engine give 210psi across all 4 with a compression ratio of approx 10.6-1
Mark Allanson
posted on 16/5/10 at 02:11 PM Reply With Quote
Try a set of plugs, I have had 2 go like that recently, once in the 7 and once in the Dub
RAYLEE29
posted on 16/5/10 at 04:45 PM Reply With Quote
hi, 180 sounds good and agreed plugs first
should of been able to tell by the colour when you had them out
just cause they spark when theyre out doesnt mean they are working under compression
Ray
snapper
posted on 16/5/10 at 05:45 PM Reply With Quote
180 on all 4 is good so no issues there.
Swap a pair of leads to see if it's a lead problem, if not take out the plug and swap for a good one.
I eat to survive
I drink to forget
