Author: Subject: tin top turbo problems
will121
posted on 17/5/10 at 07:16 PM Reply With Quote
ive got a renault DCi with what sounds like a death turbo rattle! took the air inlet pipe off and there seems to be an excessive amount of end float in the spool, should there be any in/out movement in the air compressor spool? and if so how much is ok?
thanks
posted on 17/5/10 at 07:24 PM Reply With Quote
Fit a recon unit before it destroys the engine -----
zilspeed
posted on 17/5/10 at 07:27 PM Reply With Quote
thanks
The end float should be in the order of 1 to 3/1000th of an inch.
Feck all in other words.
turboben
posted on 17/5/10 at 08:48 PM Reply With Quote
Check the intercooler - might be filled with oil. You cant switch off a diesel when its running on its own oil!
prawnabie
posted on 17/5/10 at 09:01 PM Reply With Quote
Renault will not give warranty on a turbo fitted without a intercooler, air pipes, oil feed pipe and drain pipe.
