Author: Subject: Fixing trigger wheel to pulley
L5W
posted on 20/5/10 at 05:46 PM Reply With Quote
I picked up a trigger wheel at Stoneleigh and have had a shallow recess machined off the front of my zetec crank pulley to centre the trigger wheel. Is it ok to simply weld the trigger wheel onto the pulley?
The chap who did the machining for me said the pulley machined like it might be cast so I'm not sure if this would cause problems when welding
I was thinking about using my mig to weld small beads in 4 or 6 places round the circumference
cheers,
Lee
blakep82
posted on 20/5/10 at 06:02 PM Reply With Quote
what are those 3 holes i can see in the pulley? if they're threaded, bolt into them
________________________
omega0684
posted on 20/5/10 at 06:33 PM Reply With Quote
i bolted mine on using grub screws and loctite
adrianreeve
posted on 20/5/10 at 06:46 PM Reply With Quote
I wouldn't weld. If it's cast, it'll fail eventually, and likely distort when you weld it anyway. Drill and tap I'd say.
Adrian
L5W
posted on 20/5/10 at 08:41 PM Reply With Quote
Thanks for the replies, will go the drill & tap route instead
norfolkluego
posted on 20/5/10 at 09:03 PM Reply With Quote
Adrian
Took ours to a professional Welderman, they can do it
big_wasa
posted on 20/5/10 at 09:11 PM Reply With Quote
they also have a rubber damper in them. Like a dual mass setup.
I woul drill and tap. Atleast you can move it.
posted on 20/5/10 at 10:21 PM Reply With Quote
I would also suggest tapping and bolting. It might be worth adding a pin and drilling a small hole in the trigger wheel to locate the trigger wheel on the pulley (ie so if you take it off and put it on again the timing won't go all over the shop if you put it on 90 degrees off).
