Author: Subject: Pinto Clutch Friction Plate
big-vee-twin
posted on 25/5/10 at 06:26 PM Reply With Quote
Does anyone know how many 'Horsepowers' can be put through standard Pinto friction plate
http://www.triangleltd.com
tomprescott
posted on 25/5/10 at 06:28 PM Reply With Quote
At a guess I would say circa 200 but may be more. Does the cosworth yb use the same clutch?
A bird in the hand....
flak monkey
posted on 25/5/10 at 06:30 PM Reply With Quote
About 180-200 is the limit for a standard pinto clutch...considering thats double the power of the std engine thats not bad!
The cossie uses a 240mm plate rather than the 215mm one on the pinto.
So if you wanted to you can use a cossie flywheel and the bigger clutch. Heavier though...
Sera
http://www.motosera.com
big-vee-twin
posted on 25/5/10 at 07:55 PM Reply With Quote
Hi David,
I've got hold of a heavy duty RS Turbo pressure plate 220mm to fit the ST150 flywheel, so I think its good for 180-200 HP as a standard one was 135HP??
I was just wondering if it would be worthwile investing in an uprated friction plate too
RAYLEE29
posted on 25/5/10 at 08:57 PM Reply With Quote
But you would also need the cossie crank and a t5 box as its also a bigger dia and a 10 bolt fixing.
Ray
flak monkey
posted on 25/5/10 at 09:02 PM Reply With Quote
I am using the competition rs turbo pressure plate and a race pinto friction plate (organic not paddle) and that doesnt slip with 265bhp and 245lbft....
I would go for a fast road pinto plate and it should be fine Mind you i dont think theres much difference in the cost of the fast road and race ones...so buy the best you can
Sera
big-vee-twin
posted on 25/5/10 at 10:12 PM Reply With Quote
Thank you
mcerd1
posted on 25/5/10 at 11:14 PM Reply With Quote
Ray
a cossie crank has 9 bolts
and they are on an odd spacing so you can only fit the flywheel one way round as they are ballanced together in the factory
so if you get a cossie crank and flywheel, you want them both from the same engine or you'll need to get them ballanced
also if your going to put alot of power throught a pinto flywheel you'll want to think about getting the flywheel doweled onto the crank (the cossie setups extra bolts do the same job)
[Edited on 25/5/2010 by mcerd1]
posted on 26/5/10 at 07:32 AM Reply With Quote
Just to point out not all Pinto clutches are the same 2 litre is bigger than 1.8/1.6/1.3
DRC INDY 7
posted on 15/6/10 at 09:00 PM Reply With Quote
wrong again early pinto clutches are different sizes 190mm and 215mm
the later 1.6 1.8 2.0 are all the same size clutch 215mm
Where do i go to complain about you and your useless information
Puddle Dodgers Club
