Author: Subject: Anyone know anything about the 2.3 v6 type 9 gearbox?
adrianreeve
posted on 27/5/10 at 06:29 PM Reply With Quote
Am I right in thinking that the 2.3 v6 type 9 gearbox has the same ratios as the standard sierra box, and it's only the 2.8 and 2.9 gearboxes that have the shorter gearing? But the 2.3 does have the longer input shaft, requiring a spacer between gearbox and bellhousing if I want to use it with a zetec engine?
Adrian
spiderman01980
posted on 27/5/10 at 06:38 PM Reply With Quote
try looking on ere it might be a long read but it might answer your question!!
http://en.wikipedia.org/wiki/List_of_Ford_engines#6_Cylinder
and this page!!
http://en.wikipedia.org/wiki/Ford_Type_9_transmission
[Edited on 27-5-10 by spiderman01980]
matt_claydon
posted on 27/5/10 at 06:52 PM Reply With Quote
I didn't think there was a 2.3 V6? Prepared to stand corrected though!
spiderman01980
posted on 27/5/10 at 06:57 PM Reply With Quote
it was called a Cologne/Taunus V6
they came in 1.8L up to 4.0L
Mr G
posted on 27/5/10 at 07:52 PM Reply With Quote
Yes I had a Cortina 2.3S
Used in the 2.3 Sierra as well.
snapper
posted on 27/5/10 at 08:33 PM Reply With Quote
2.3 V6 had the power of a 2L and the weight and fuel consumption of a 3L
I eat to survive
I drink to forget
Mr G
posted on 27/5/10 at 08:41 PM Reply With Quote
Sounded nice with the air filter housing removed though
matt_claydon
posted on 27/5/10 at 08:54 PM Reply With Quote
I do indeed stand corrected
scotty g
posted on 28/5/10 at 08:06 AM Reply With Quote
I thought the 2.3 was an Essex V6 and the 2.4 that went into the later granada's was a cologne?
cheers
Mr G
posted on 28/5/10 at 02:39 PM Reply With Quote
2.3 definately cologne
robinj66
posted on 29/5/10 at 07:54 AM Reply With Quote
The T9 ratios for the 2.3 V6 in a granada 2 were the same as the 2.0 (Pinto) engine :
3.65 : 1 (3.36)
1.97 : 1 (1.81)
1.37 : 1 (1.26)
1.00 : 1 (1.00)
0.816 : 1 (0.825)
The figures in brackets are for the 2.8 gearboxes
The Sierra seemed to fit the same T9 'box to all 4 pot engines (except the P100 vehicle) and the ratios are the same as the 2.0/2.3 above except the 5th gear which is quoted as 0.82 : 1.
Sorry - I don't have figures for the V6 Sierra gearbox
The Granada 3/Scorpio fitted the same ratios as the 2.0/2.3 Granada 2 but the 2.8/2.9 T9 'boxes had the following:
3.36 : 1
1.81 : 1
1.26 : 1
1.00 : 1
0.825 : 1
All figures from Haynes
[Edited on 29/5/10 by robinj66]
Liam
posted on 30/5/10 at 11:41 PM Reply With Quote
cheers
2.3 is to 2.4 as 2.8 is to 2.9. All colognes.
