bi22le
| posted on 5/6/10 at 11:31 AM |
Topping up oil on type 9 + diff help
A painfully basic question.
I have a typr 9 gbox and I need to top up the oil becasue I think I have a leak.
Is this the refill? Its on the left but seems very low.
  gearbox resize
Also I have a 7" 3.92:1 non LSD sierra diff with push in shafts. I cant see a top up bolt anywhere. All I have is a breather tube at the top.
Where is the top up bolt?
Please read my ring story:
mangogrooveworkshop
| posted on 5/6/10 at 11:44 AM |
Top up for the diff is on the back plate its a torx .
The cheat is to put a funnel on the breather and put oil in that way but you have no way to know how much you have in it
TORX 55 to be eaxct
[Edited on 5-6-10 by mangogrooveworkshop]
tomgregory2000
| posted on 5/6/10 at 11:50 AM |
and the gearbox is a BIG allen key about half way up the main case
bi22le
| posted on 5/6/10 at 12:16 PM |
The only torx bolts on the back plate of the diff are the ones holding it on!!
Ill have another look though.
Also I have found a large allen bolt on the side on the gbox but I would safe its well below half way down. As per the pic in OP.
Thanks for your help.
Any other advice or opinions about this would be good.
Also can I put GL5 in a GL4 stated gbox?
Mr G
| posted on 5/6/10 at 12:26 PM |
See my pictures at the bottom of THIS thread for the 2 different type 9 filler
plug locations.
Davg
| posted on 5/6/10 at 12:29 PM |
Diff level/filler plug is allen plug on the right hand middle of the back plate.
mangogrooveworkshop
| posted on 5/6/10 at 12:43 PM |
bi22le
| posted on 5/6/10 at 04:42 PM |
Ah my fuel tank is well in the way!!!
