Author: Subject: Twin Side Draughts or Motorbike Carbs???
Barksavon
posted on 8/6/10 at 08:59 PM Reply With Quote
Ive got a 2L pinto on twin Dellorto 40 DHLA's in a Tiger. I'm getting a bit P'd off trying to get it run consistently well, it was running reasonably but bogging down on acceleration so opened up the idle screws 1 1/2 turns and it got better but went out in it few days ago....ran like a pig for about 4 miles then cleared itself, been out tonight and running like 2 pigs, plugs black and wet so presume running way too rich now, wound the screws bak in and wire brushed the plugs, only a bit better...aaaaaargh!!!!! Thinking about bike carbs are they easy to fit and maintain do they stay in tune once set up unlike the carbs ive got on at moment...Any comments/views/advice welcome.
whitestu
posted on 8/6/10 at 09:03 PM Reply With Quote
Dell'ortos in good condition and set up well shouldn't go out of tune. I've had several Alfas with them on and they consistently worked well.
Having said that the bike carbs on my Zetec were dead easy to set up, and cost less than a service kit for a set of Dell'ortos.
Stu
55ant
posted on 8/6/10 at 09:04 PM Reply With Quote
couldnt be happier after changing from a 38 dgas to bike carbs, changed the car completely.
away from cars, now cycling and building TT bikes
jacko
Bike carb all the way
I fitted zx9r carbs and it was the best thing i have done
They stay in tune easy to fit and never bog down
I made my own manifold
look in my photo archives under zx9r / manifold
Jacko
norfolkluego
posted on 8/6/10 at 09:05 PM Reply With Quote
Only just fitted ours so can't give a long term view but they're certainly much cheaper to buy and seem easier to maintain (change jets etc.)
dlatch
posted on 8/6/10 at 09:08 PM Reply With Quote
throttle bodies
b16mts
posted on 8/6/10 at 09:15 PM Reply With Quote
I built my pinto tiger with twin weber 45's. gave up even before SVA, flogged them as nearly new, but a set of gsxr600 carbs inc manifold, and pockets the £300 change!!
plus it now make 119bhp at the flywheel with nothing but a lumpier cam.
happy days!
Martin
who says you can't drive a kit car when you're 6'5"?
Paul TigerB6
posted on 8/6/10 at 09:16 PM Reply With Quote
Neither - get it to a rolling road and set up properly.
If starting from scratch i'd say bike carbs but have you actually had the DHLA's properly set up on a rolling road?? If not then its highly unlikely to have the right main or idle jets for the fueling so you can mess about with the idle screws till the cows come home - you'll never get anywhere.
RichardK
posted on 8/6/10 at 09:25 PM Reply With Quote
Bike Carbs everytime.
Rich
Gallery updated 11/01/2011
Barksavon
posted on 8/6/10 at 09:43 PM Reply With Quote
Bike Carbs definately come out on top here then....Paul thanks for the reply, ive had the car on a rolling road, nice guy but he specialised in MG's and didnt alter the jetting at all, he did get the car running better than it was but it still wasnt as good as it could be. I'm thinking bike carbs are the way forward, i could spend a fortune with what ive got on (which i bough off e bay!!) and still get nowhere.
Thanks for the other replies as well guys much appreciated.
Paul TigerB6
posted on 8/6/10 at 09:56 PM Reply With Quote
Bit of a difference between a set of twin SU's that MG's generally have and a pair of DHLA's. You'd really need them set up by a decent rolling road who know DCOE's and DHLA's as they take some knowledge to get right - especially around the progression between the two sets of jets.
Anyway, you'll generally get a good price for the DHLA's on ebay - twin sidedraughts still seem to sell really well even with the bike carb phenomena. If fitting bike carbs then it'll be a wise move to also fit a bike pump at the rear below the tank (they work more efficiently pushing fuel). Do you have a Facet or similar electric pump, or the standard mechanical one under the carbs?
madteg
posted on 8/6/10 at 09:59 PM Reply With Quote
Fitted twin fourties to mine when first built couldn't afford the petrol. Getting more to the gallon now with turbo.
jimgiblett
posted on 8/6/10 at 10:08 PM Reply With Quote
Stu
My Dellortos on my Alfa havent caused any problems either.
- Jim
atspeed racing
posted on 8/6/10 at 10:21 PM Reply With Quote
A correctly set up fuel system, EFI or carbs should never need to be reset up. If it needs to be redone, it was either not set up correctly in the first place, or something on the car has made a change for you.
Having said that, a CD type carb like an SU, Stromberg or bike carb would be far more tolerant to low carb air speed due to a performance camshaft , large ports, scavenging exhaust or a big valve head being fitted. This is exaggerated on a very light car such as a kit car and would feel that the car has a serious running problem (misfire).
This is why the bike carbs are so good, they dampen the irregularities brilliantly, but then so would SU carbs.
A pair of DCOE's or DHLA's set up correctly should not need to be adjusted ever, and as an earlier poster has said, the problem is down to getting the progression correct between the idle and where the main circuit takes over. This is the hardest thing to get correct and this is an area that most tuners fall down on. They spend all there time trying to get the big number and dont concentrate on the cars drivability
Hope my input helps.
r1_pete
posted on 9/6/10 at 06:59 AM Reply With Quote
I see you're in Derbyshire, anywhere near Chesterfield?
If you can get the car to Eike Wellhausen at Chatsworth Motor spares, hes a weber / delorto specialist, and will sort them for you, he's just done the triple webers on my Jag.
He also Races a Lister Replica with triple dcoe's, and had 2 other E's in when I took mine, he is THE man for Webers.
Barksavon
posted on 9/6/10 at 04:57 PM Reply With Quote
paul yes ive got a facet pump mounted very close to the bottom of the fuel tank, would that be okay for bike carbs or would i def need a bike fuel pump. Other replies thanks a lot, i know Chatsworth motor spares as i live Alfreton and got my cable linkage from him so may give him a call, i think it is a progression issue...its how much cash and patience i want to spend sorting it out
Paul TigerB6
posted on 9/6/10 at 07:19 PM Reply With Quote
Some have used the Facet succesfully but personally i'm not a fan. The bike carbs only need about 1.5psi so probably just over half what your current carbs use. A bike pump is designed to pump the volume at the low pressure and self regulates. Regulate a Facet down to 1.5psi and i'd personally worry about fuel starvation under hard acceleration. There's enough people swapped from a Facet to bike pump and cured their running problems to convince me its the better long term option.
Probably worth looking for a bike pump on ebay - most bikes of 600cc plus will have a near identical pump so most will work with any bike carbs (which will probably be Mikuni or Keihin regardless of bike make) and then sell on the Facet and regulator with or without the carbs.
Bike pumps are cheap enough and are very reliable.
http://cgi.ebay.co.uk/Honda-CBR-900-Fireblade-Fuel-Petrol-Pump-And-Filter-/250643915996?cmd=ViewItem&pt=UK_Motorcycle_Parts&hash=item3a5b8aa4d c#ht_515wt_1137
Barksavon
posted on 9/6/10 at 07:29 PM Reply With Quote
nice one mate thanks.....rang Bogg Bros today, £600 for carbs, manifold, pump etc, bit more than i hoped but still might take the plunge, are bike carbs less thirsty with the petrol than the side draughts, i think ive read somewhere that they are...ive not measured my mpg but dont seem to get much
prawnabie
posted on 9/6/10 at 07:38 PM Reply With Quote
Get the sidedraughts set up on a rolling road you wont look back! I think too many people jump on the "webers etc dont stay in tune for long" bandwagon which in my opinnion is an old wives tale.
tul214
posted on 9/6/10 at 07:45 PM Reply With Quote
I swapped from Bogg Bros set up DHLA's to CBR 600 carbs on a home made manifold and took the car back to Boggs.
Both set ups made the same power BUT the bike carbs are SO much smoother and do not bog down coming on to power from low revs/speed.
I sold my Dellorto's and facet pump and regulator for £300, the bike carbs were £50, the bike fuel pump about £20 and the manifold cost me about £50 all in.
NTDWM but FASTDAN on here is selling manifolds cheaper than Boggs and then just find some carbs on e-bay. Should cost you no more than £200 plus a RR session to jet them.
Mark
1.6 Raw Super6 sold
