black fingernail
| posted on 10/6/10 at 02:22 PM |
unkown connector
This has really confused me now. It definatly come out of a puma I saw it. no idea why it has the 2 extra relays. if I cant figure it out I may
have to buy you loom/fuse box off you..
This is the only connector I cant find where it goes. Its on the same batch of wires c102. Im thinking its the speed sensor they are all black.
tegwin
| posted on 10/6/10 at 02:25 PM |
Any chance of a bigger picture? Cant quite see it
www.verticalhorizonsmedia.tv
| posted on 10/6/10 at 02:31 PM |
Phew...
Davegtst
| posted on 10/6/10 at 02:38 PM |
Looks like the old Ford 3 pin diagnositc conector before they went over to eobd. Strange if it's from a puma.
big_wasa
| posted on 10/6/10 at 03:06 PM |
That is the speedo plug for the gearbox.
If you use the speed sensor it should cut fuel on over run giving you better mpg, emisions and stops it poping.
Ive done a few and they seem to run fine with out.
The ford sensor is a "Hall sensor" three wires . One is switched live, one is earth the other is signal out.
I am using the sensor to run my dash.
[Edited on 10/6/10 by big_wasa]
