release bearing problem
Well, ive just been out to see if i can measure the thickness of the proposed adapter plates, and i have realised that the release bearing is too
small for the capri clutch cover.
Anyone know if i can increase the diameter of the bearing and insert it into the existing assembly? The diameter of bearing i need is the same as the
diameter of the spring clip here.
  release bearing 1
[Edited on 13-6-10 by MakeEverything]
Kindest Regards,
Richard.
