Bumble
| posted on 13/6/10 at 08:31 PM |
Zetec.....which Inlet Gasket???
Can anyone tell me the Ford part no. for the correct Inlet manifild gasket for a '97 Silvertop or where to buy one online. There's one on
e-bay
LINK which I bought and it's the wrong type??
Thanks,
Matt
big_wasa
| posted on 13/6/10 at 08:38 PM |
There not cheap Matt.
Best part of 30 quid from Burton power ect.
There are two types The one you want is from an escort with the alloy inlet manifold.
The other is any other zetec and is a rubber coated thing that has channells in it for the egr..
Either will work.
If you can not find one let me know are you going to Newark ?
[Edited on 13/6/10 by big_wasa]
will121
| posted on 13/6/10 at 08:56 PM |
that gasket you show in ebay link is not the manifold to head one, its the standard injector plate to manifold, as said the fiesta/escort ones are £30
ish, what are you fitting it to? if throttle bodies on a manufactured inlet manifold there are lots just using home made gaskets out of paper, main
advantage of using the propper one is if you ate using the standard zetec inlet with the crank case breather still connected.
Bumble
| posted on 14/6/10 at 09:00 AM |
I think I've caused some confusion. It's the Sandwich late Gasket I require similar to the one linked to on the Bay but that actually
fits my engine?
Can anyone help point me to the correct one?
Thanks,
Matt
big_wasa
| posted on 28/6/10 at 08:47 PM |
In the post Matt.
