dan8400
| posted on 14/6/10 at 09:00 AM |
Bike Carb Manifold - Quick question
Can i get away with using longer pieces of rubber hose and not fabricating bendy bits of steel pipe?
Not much of a fabricator/welder and not flush on cash to have it modded atm.
I have a zetec back plate with short pieces (50 - 60mm) straight tube welded to
Dan
Hey - That's Journey!!!
whitestu
| posted on 14/6/10 at 09:23 AM |
Which carbs are they? Respace the bike carbs to suit the manifold - it's not that difficult or expensive.
The fuel pipe bits need someone with a lathe to turn them so the o rings fit, but I'm sure you can get that done by someone on here. The rest is
basic metalwork to set the carbs at the right distance apart and extend the linkages.
My set up doesn'y have any bits of steel pipe - just the original bolt on Kawasaki rubbers and a piece of Ali plate to bolt up to the head.
Stu
dan8400
| posted on 14/6/10 at 09:26 AM |
someone on here very kindly made me some brass spacer pipes for some zx6r carbs which i spaced.
The only problem is they keep coming out of balance. Due to the spacings. I have a set of 1100 carbs i got from a bloke at work for £20 this morning.
thought this would solve my problems as i dont fancy spacing/ruining another set of carbs.
Dan
[Edited on 14/6/10 by dan8400]
UncleFista
| posted on 14/6/10 at 09:42 AM |
If you tried to make a manifold with long hose lengths, I reckon the hoses would collapse due to pressure/vacuum as soon as the engine was started..
Tony Bond / UncleFista
whitestu
| posted on 14/6/10 at 09:50 AM |
I have respaced ZX6Rs on my Zetec and they seem fine. Any reason why they are coming out of balance?
If it is any help I have a homemade manifold for non respaced ZX6R carbs. It is designed to work with the ZX6R carb rubbers.
It's not very well made, but works fine. Ideally it could do with brazing internally to smooth the ridges - at present I have done this with
chemical metal.
If you are stuck you can have it for £20, which is what the manifold plate cost me. There are some pics in my archive in a folder called inlet.
Stu
Stu
r1_pete
Exactly, if the hoses were long enough they would collapse completely stopping mixture getting to the engine.
Either way, the constant collapse / re-expand, would soon lead to hose failure.
Why are your carbs going out of synch?
any pics how you've re-spaced them?
that would be the problem to tackle.
dan8400
| posted on 14/6/10 at 10:29 AM |
The problem is the springs that operate the carbs. my zx6r carbs have the cable one end which opens the first carb then there is a spring loaded plate
which opens the next and then the next.
The springs dont have the power to stop number one opening slightly more than two and so on
Dan
dan8400
| posted on 14/6/10 at 10:32 AM |
I tried putting in self tappers instead of springs but cant get them tight without the throtlle jamming open and not returning.
So i thought a clean slate with a fresh set of carbs (off an 1100 i think) but not spacing them or mucking around with how they operate would be
better option.
Dan
r1_pete
| posted on 14/6/10 at 12:46 PM |
The springs you mention, only keep each spindle cam tang in contact with the adjuster screw on its neighboring carb (For return), it is the screw
which presses on the tang and opens each carb.
If you are pressing on the spring you have something assembled wrong.
I have seen these tangs extended when the carbs are spaced, and then they flex due to their extra length. They need some bracing to stop the
flexing.
[Edited on 14/6/10 by r1_pete]
