austin man
| posted on 15/6/10 at 10:28 PM |
ECU flashing remapping
has anyone on here used one of these units if so what was the outcome, I have a Golf 1.8 turbo 150 bhp and looking to squeeze a bit more power for
locost. Alternative price is £250 for a remap
http://cgi.ebay.co.uk/041-UK-KWP2000-ECU-Remap-Tuning-Tool-Flasher-Tune-Map-/320537594621?cmd=ViewItem&pt=UK_Diagnostic_Tools_Equipment&hash=i
tem4aa1878afd
dlatch
| posted on 15/6/10 at 10:32 PM |
as i understand it that kit will just reflash the ecu with a new map
if you don't have the map file to flash then its completley useless
don't know if you can save original map so you can re flash back to standard but if you can then i would guess it may just work bit risky though
these things have a way of going wrong or tits up as its known
austin man
| posted on 15/6/10 at 10:40 PM |
it states that it can upload and download also allow the user to adjust individual settings
franky
| posted on 15/6/10 at 10:49 PM |
You'd be better off getting a custom re-map on a rolling road once you'd adapted it to suit your kit application.
austin man
| posted on 15/6/10 at 11:03 PM |
the engines not going in a kit Its my daily driver
| posted on 15/6/10 at 11:12 PM |
Without a rolling road session or fitting a wideband sensor, how will you know the fueling is safe?
austin man
| posted on 16/6/10 at 09:45 AM |
apparently it comes with loads of pre made maps for a wide range of cars. It appears that no one has used one as far as I can see. I dont fancy being
the first to try then have to cry
SALAD
| posted on 16/6/10 at 12:06 PM |
I found this when I had my HDi.....didn't try it though.
http://www.youtube.com/watch?v=Lo6WmQ0aPUM&feature=related
RazMan
| posted on 16/6/10 at 01:56 PM |
I'd say it is rather risky to upload someone else's map and expect a power increase - so much depends on your individual engine's
setup and you could seriously damage your engine. If however you first install a wideband lambda sensor and gauge, it looks quite useful if you are
able to tweak the right settings.
[Edited on 16-6-10 by RazMan]
Raz
