Author: Subject: Diesel Expert advice needed
v8kid
posted on 21/6/10 at 12:18 PM Reply With Quote
I have the following fault codes with my 05 2.2TDi Mondeo.
P0401 EGR flow insufficient
P0403 EGR flow circuit malfunction
P0405 EGR flow sensor A circuit low input
Took the EGR off cleaned all the muck out and cancelled coded.
All fault codes came back after a run.
Symptoms are the car goes great! A little black smoke out the back on acceleration - used to be a lot of black smoke before I cleaned the EGR This model has a servomotor EGR rather than the earlier vacuum one and looks expensive!!
Do I need one?
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
jossey
posted on 21/6/10 at 12:33 PM Reply With Quote
P0403 EGR is the solenoid fault. my little brother had that error.
dunno about rest
dave
