Author: Subject: Info wanted about a corsa engine please
jacko
posted on 22/6/10 at 07:53 PM Reply With Quote
Hi All the Wife's 1000cc 3 cylinder engine is in need of a cam chain etc and a new clutch
is it possible to remove the engine and leave the gear box / drive shafts etc in place
Thanks Graham
vyperstrype
posted on 22/6/10 at 08:42 PM Reply With Quote
Corsa
I would take engine and gearbox out as one unit. I don't think you would get enough freedom of space to split engine from gearbox in situe. Even if you could, it would be an absoloute pig to put back in to allign clutch etc..
Cheers Eric.
Where there's a will, there's a death!!
jacko
posted on 22/6/10 at 09:13 PM Reply With Quote
How do you remove the drive shafts ?
please
RichardK
posted on 22/6/10 at 09:28 PM Reply With Quote
u2u sent m8
Gallery updated 11/01/2011
posted on 23/6/10 at 08:52 AM Reply With Quote
Leave the engine in and do the jobs separately or take the complete unit out.
Re-camshaft take the cover off and look for loose bolts before you start the job, however it is likely it is a lubrication issue that caused the problem ie "gunge" .
These engines need to be run on 5w/30 fully synthetic changed at less than the manufacturers service interval.
posted on 23/6/10 at 08:54 AM Reply With Quote
Drop the whole lot out the bottom the opposite way to it being assembled?
