Author: Subject: 4wd from a front-wheel drive engine?
PSpirine
posted on 27/6/10 at 11:55 AM Reply With Quote
Whilst looking at possible engines for my 7 project, something caught my mind, completely unrelated to my engine choice.
There are a lot of FWD engines/boxes from FWD cars..
If you were to simply turn the engine 90 degrees, and use the existing gearbox driveshaft output flanges, simply run two props one to the front, one to the rear, would there be any problems of doing that and having a really simple 4wd transmission?
The biggest problem I see is getting the weight of the engine/box central, so the props will have to most likely be offset to one side, but surely that's not such a massive problem?
Anybody ever heard of this or thought of this before?
MakeEverything
posted on 27/6/10 at 11:59 AM Reply With Quote
You would then have three differentials.
Not sure the gearing would be effective unless the front diff and the rear diff are 1:1, and the gearbox diff is used as the main final drive.
Would put a hell of a lot of strain on the box though.
Kindest Regards,
Richard.
PSpirine
posted on 27/6/10 at 12:26 PM Reply With Quote
Don't all awd cars have 3 diffs?
I can see how the gearing can be a bit of an issue, but in terms of strain on the box, I doubt that's a problem if you use it in a car as light as a seven or other kit car
Pavs
MkII
posted on 27/6/10 at 12:40 PM Reply With Quote
the center diff in most 4wd cars is 1:1 ratio the diff in a fwd gearbox will be more like 3.9:1 which is what will significantly reduce your gearing. .m.
hillbillyracer
posted on 27/6/10 at 12:55 PM Reply With Quote
It a layout used in off-road stuff, the gearing works to their advantage meaning they can use large diameter wheels for better ground clearance while keeping the speed low.
It does mean that the front & rear diffs have a lot of torque to handle though.
fha772
posted on 27/6/10 at 01:27 PM Reply With Quote
I know of a lad that used this idea in an off road buggy, using a Peugeot 309 diesel.
It worked brilliantly, but it was very low geared (which was ideal in this buggy), it's top speed was about 30-35mph. But it would crawl over anything.
So, if you could lower the diff ratios, it would be a good concept, it's just a case of how much a custom ring and pinion would cost, to get as close as possible to a sensible road speed.
Maybe it would be easier if you could alter the axles and the centre diff ratios, and spread the ratio through all 3 diffs, instead of putting all the load on 1 diff alone.
http://www.ppcmag.co.uk/forum/viewtopic.php?f=47&t=6743&start=105
turbodisplay
posted on 27/6/10 at 03:46 PM Reply With Quote
I have thought about that before, would make a simple 4wd mid engine.
Options are:
1)Make the box ratio 1:1 either by gearing or using an inverted tooth chain.
Unlikely to have the room to make 1:1, but might be able to have some reduction of ratio.
2) have 1:1 bevel gearing connected to the diffs, so would require custom gears and a custom enclosure. The prop shafts will need to take 3 times the torque, so even a modest engine till require a strong prop.
You would need a gearbox with lsd, eg fiat coupe turbo, rs turbo etc.
Darren
posted on 27/6/10 at 05:28 PM Reply With Quote
Wouldn't you have to lock the differential to make it power front and rear wheels at the same time ? The proper ones use a transfer box not a differential in the middle so you can select what drive you want.
[Edited on 27/6/10 by Peteff]
fha772
posted on 27/6/10 at 05:30 PM Reply With Quote
Originally posted by turbodisplay
...You would need a gearbox with lsd, eg fiat coupe turbo, rs turbo etc...
Simple, any ford escort engine fitted with a RS box, oreven a RS LSD in a standard box.
turbodisplay
posted on 27/6/10 at 05:35 PM Reply With Quote
No the diff is open in the centre, as if you did have it locked, the difference in speed will cause wind up, until the wheels scrubbed. It needs to be a lsd.
Ways 4wd cars cope with speed difference is:
Open and locked in low grip situation
Viscous coupling
Clutch
Open diff with lsd.
Darren
[Edited on 27/6/10 by turbodisplay]
Liam
posted on 27/6/10 at 09:45 PM Reply With Quote
As above - LSD in the centre and at least one other (normally rear), find/build 1:1 front/rear diffs and job's a goodun. You would be stuck with a 50:50 front/rear torque bias though.
fha772
posted on 28/6/10 at 08:53 AM Reply With Quote
50:50 torque bias would be fine in an off-roader, but could be a problem in a road car.
posted on 28/6/10 at 12:38 PM Reply With Quote
Unless you could find some 1:1 diffs front and back you would end up with just under 8:1 reduction..
Not good unless you want a screaming rock crawler...
coyoteboy
posted on 29/7/10 at 08:01 PM Reply With Quote
Incidentally lots of road cars have an approximately 50:50 torque split, the celica GT4 for example. (visccous coupled centre, torsen rear, open front).
