Author: Subject: camshaft spec for rs2000 pinto
westf27
posted on 29/6/10 at 12:37 PM Reply With Quote
can anyone give me the spec for the standard rs2000 camshaft fitted in the pinto engine.Valve clearances and timing settings would be very useful.
thanks
steve
555
Hugh_
posted on 29/6/10 at 01:34 PM Reply With Quote
Standard clearances of all Ford cams in the pinto as far as I know are 0.2mm on the inlet and 0.25mm of the outlet.
Alot of the more manly aftermarket cams use the same clearances. The milder ones tend of have slightly larger clearances.
Your call, but I reckon you'd be fairly safe with 0.2/0.25
JeffHs
posted on 29/6/10 at 04:12 PM Reply With Quote
As per Haynes for RS2000
lift 6.3323 mm (0.2494 inches)
inlet opens 24 degrees BTDC
inlet closes 64 degrees ATDC
exh opens 70 degrees BBDC
exh closes 18 degrees ATDC
JeffHs
posted on 29/6/10 at 04:14 PM Reply With Quote
missed clearances from post
inlet 8 thou .020 mm
exh 10 thou .025 mm
westf27
posted on 29/6/10 at 04:29 PM Reply With Quote
thanks guys
555
