Author: Subject: what engine??
dilley
posted on 30/6/10 at 04:50 PM Reply With Quote
what engine??
Hi Guys,
I have been thinking about my buggy project, now, I would love a bike engine but, It is an off roading machine, and I do not think that climbing huge hills is going to do it much good, including all the water and mud etc. I know that rage build one, I am now thinking of diesel powered???!!! peugeot 1.9 td, I can tune one of these to about 110bhp with some tweeks and an intercooler, estimated weight should be around 550kg. what do you think??? It should perform quite well and have bags of tourqe off road. Plus its a very cheap option, I have an engine and box, wiring is as basic as ever and I do not have to worry about a chain diff and reverse....
whitestu
posted on 30/6/10 at 04:52 PM Reply With Quote
Sounds like a good idea to me.
Get a raised air intake and you can go through some deep water as well!
Stu
matt_gsxr
posted on 30/6/10 at 05:01 PM Reply With Quote
the only problem I see is that with Diesels in lightweight cars is that you get no sound insulation so they can be a bit noisy.
But I have a BEC with a solid mounted engine, so I am already a bit deaf already.
Matt
posted on 30/6/10 at 05:03 PM Reply With Quote
Either a Mondeo 1.8 or a Rover T16 going in my off roader, just depends on what gearbox arrangement I decide upon.
So its either 150 or 210 bhp!
dilley
posted on 30/6/10 at 05:10 PM Reply With Quote
Engine in the rear so noise should not really be a problem, does anyone know the power of the corsa 1.5 td engine?? it looks quite compact!!
I think this could be a good time to discuss torque over horse power!!!
Bring on the black soot!!!
[Edited on 30/6/10 by dilley]
dlatch
posted on 30/6/10 at 05:55 PM Reply With Quote
if its for off road mainly then i think the reliable and simple 1.9td lump would be perfect and plenty power
dinosaurjuice
posted on 30/6/10 at 06:04 PM Reply With Quote
nothing wrong with diesels in kitcars i think a 1.9 vw tdi would be the better choice, an early one with a bosch mechnical injection pump is easily tuneable.
dilley
posted on 30/6/10 at 07:16 PM Reply With Quote
the current engine is a 3 cylinder petrol, I need a very narrow engine and gear box assembly, I think I can probably go 120mm wider...
dilley
posted on 30/6/10 at 07:24 PM Reply With Quote
Does anyone have any length measurements for the vw tdi engine and box?? corsa 1.5td?? peugeot 1.9td??
spiderman01980
posted on 30/6/10 at 08:13 PM Reply With Quote
try and see if you can fit a ford transit engine they are made to carry 3.5t or a transit connect
AndyGT
posted on 30/6/10 at 08:59 PM Reply With Quote
if your 3 cylinder is from a corsa then the 1.5 may just be the simplest option as I imagine that the gearbox would be similar/same except ratios. And a small petrol engine is likely to have very low ratios indeed ideal for off-roading...
nothing is impossible
everything is possible
Stott
posted on 30/6/10 at 09:13 PM Reply With Quote
BEC it, my mate built 2, one blade powered 2 seater and a 600 powered single seater, did about 120mph flat out (regularly - bouncing off their limiters in top up the forestry roads) awesome things.
It's only the same power charecteristic as a 2 stroke and keep them singing and they'll go up a wall, I've never had any trouble (on 2t bikes)
Also depends what your definition of off road is, if it's more like WRC then BEC it IMHO, or if you want to go crawling about then yeah you could use a diesel I guess
dilley
posted on 30/6/10 at 10:27 PM Reply With Quote
Had a measure up and I cannot get a decent car engine in...... I need a tourqey bike engine, v twin??
Stott
posted on 1/7/10 at 07:15 AM Reply With Quote
sv/tl1000 lump, they have got lots of pull and should be quite available/not too expensive
