RMarine
| posted on 2/7/10 at 06:49 PM |
timing belt needed
Hi, I have now a Daihatsu alternator that it fits great and i now know how to wire it to the car. BUT i need a timing belt that is around 870mm long.
i have already tried a 900mm and its to big. Do they make timing belts that small or do i need to cut or weld things, add washers and/or pull my hair
out and struggler with the 900 long belt?
[Edited on 2/7/10 by RMarine]
Paul TigerB6
| posted on 2/7/10 at 06:52 PM |
you mean a drive belt. Are you looking for a ribbed belt or v-belt??
The length is usually incorporated into the product code anyway
FrankP
| posted on 2/7/10 at 06:53 PM |
Pretty sure your after a fan belt not a timing belt.
I went to my local motor factors and they sold me a belt of the correct length.
Frank
RMarine
| posted on 2/7/10 at 06:55 PM |
your both right, i mean a fan belt..... Doh.
Frank, what size belt did you get? and its a ribbed belt.
Paul TigerB6
| posted on 2/7/10 at 07:05 PM |
motor factors or even Halfords should have them. the codes run something like 5875 meaning 5 rib, 875mm long and so on.
I think they generally come in 25mm increments.
mcerd1
you could have a look on the gates online cataloge http://www.gates.com
but it'll be easier if you just take the belt you've got to a decent motorrfactor and tell them you want one like that but 870mm long
flibble
| posted on 2/7/10 at 07:18 PM |
the 87-91 1.3l Honda civics is 4 rib 875mm long
Subaru Imprezza 93-95 alt is 5 ribbed 875 long
Porsche 928 GTS 91-95 is 6 ribbed 875 long.
One of them must fit
(and many more besides)
RMarine
| posted on 2/7/10 at 08:36 PM |
thanks all
L5W
| posted on 2/7/10 at 09:15 PM |
I'm using a daihatsu alternator too and found a Dayco belt from Camskill who have a good choice. I think mine is 6pk880, the 880 is the length,
6pk means 6 ribs or V's in the belt
Camskill Link
Lee
| posted on 4/7/10 at 09:28 AM |
"Poly-V belt "
RMarine
| posted on 4/7/10 at 04:44 PM |
found one today that fits. thanks all
