Author: Subject: Taking Pinto engine out
Tommy P
posted on 7/7/10 at 04:01 PM Reply With Quote
I'm helping FFTS to take out his Pinto engine from His MK Indy - then putting one back in.
Not a problem, but I thought it was worth asking if anyone has any tips to make it go smoothly.
We intend to remove the engine and gearbox together.
matt_claydon
posted on 7/7/10 at 04:07 PM Reply With Quote
Don't forget the clutch cable, don't forget the throttle cable, don't forget the coil-to-dizzy HT lead, don't forget the earth strap, don't forget the speedo cable, don't forget the reverse light switch connector.
All from experience
jase380
posted on 7/7/10 at 04:10 PM Reply With Quote
pretty easy to do, three of us lifted my old pinto out in about 30 mins, just get as much stuff out of the way as possible, radiator, headlight mount bar etc easier with alternator and starter off, jack car up as much as possible to allow a bit more angle for lifting the engine clear. like me dont forget to take gearlever off !!
oh and dont bash your brake pressure switch on the way out..
[Edited on 7/7/10 by jase380]
jacko
I just remove the engine i find this is the best way
Put a jack under the gearbox to hold it up
or a piece of wood across the foot well tops with a rope round the bell housing to stop the box dropping
whitestu
posted on 7/7/10 at 04:11 PM Reply With Quote
Watch out for / try to stop the oil running out of the gearbox when you take the prop out and lift the engine.
Stu
Tommy P
posted on 7/7/10 at 04:12 PM Reply With Quote
Cheers got all that, it's just manipulating the lump out and weather theres any little tips to make it a smooth removal and re-install.
Tommy P
posted on 7/7/10 at 04:21 PM Reply With Quote
More worried about lining up the splines (If we split the engine and box) when we put it back in.
r1_pete
posted on 7/7/10 at 04:33 PM Reply With Quote
Only a problem if you take the clutch off, then you need to align the friction plate with the spigot bush in the crank, a spare input shaft is an ideal alignment tool.
Anyway, whats Chris doing with a pinto? he had a drive full of BECs when I was there.....
Tommy P
posted on 7/7/10 at 04:41 PM Reply With Quote
He's had this one a while but the block cracked, so after many months out of action and nowhere to fix it, I offered my services and garage for a few days (just sold my Caterham hence, empty garage).
Hopefully my garage will be full again soon.
omega0684
posted on 7/7/10 at 05:31 PM Reply With Quote
He's making the correct the decision GO PINTO!
Fatgadget
posted on 7/7/10 at 05:36 PM Reply With Quote
Yeah, but when it comes back to refitting the engine it's a royal PITA in almost any car in my experience.
Paul TigerB6
posted on 7/7/10 at 07:02 PM Reply With Quote
As its a Pinto, you'll need an engine crane. This one should do it...................
Paul TigerB6
brookie
posted on 7/7/10 at 08:03 PM Reply With Quote
i take it the black on i looks avery nice cat that one
FFTS
posted on 7/7/10 at 09:37 PM Reply With Quote
No not "Go pinto" but the Pinto has to go so she will be up for sale soon as I'm moving house and don't have the room to keep her.
and Tom I said yes to the new pad so looks like I'll be living in Buckshaw village so will still be part of the posse
Chris.
supercat
posted on 8/7/10 at 11:28 AM Reply With Quote
Stu
This. Makes a nasty mess on the floor.
welderman
posted on 8/7/10 at 12:45 PM Reply With Quote
just poped in to say hello to the posse, toms sat in the chair pointing and telling chris what HE needs to do, nice.
Thanks for the loan of the camera too Tom
Joe
