Author: Subject: endura e 1.3 oil leak
mrwibble
posted on 8/7/10 at 09:56 AM Reply With Quote
Hi, my misses ford KA is leaving a nice black mess on our drive. the sump plug seems tight, and it only seems to leak when its warm. the filter seems ok too. i'm worried its the sump gasket, could it be anything else?
Bluemoon
posted on 8/7/10 at 09:57 AM Reply With Quote
Oil filter? Rocker cover (they leak!)..
Davegtst
The rocker cover gaskets are very prone to leaking. How far up the block/ head is the leak?
prawnabie
posted on 8/7/10 at 10:18 AM Reply With Quote
Oil pressure switch can leak too, half way up the block at the back.
posted on 8/7/10 at 10:27 AM Reply With Quote
Clean the breather pipes out with carb or brake cleaner
DRC INDY 7
posted on 8/7/10 at 11:18 AM Reply With Quote
if its a steel sump they become porus crank shaft front oil seal
as said above rocker cover gasket oil pressure switch
plus check the breather is not getting blocked
Puddle Dodgers Club
mrwibble
posted on 8/7/10 at 12:41 PM Reply With Quote
right nice one
posted on 8/7/10 at 01:47 PM Reply With Quote
in short then, take it out strip it down 'cos it could be anything.
I'd start with the simple things:- breather system and rocker cover gasket...
...after a really good look to see where's it's coming from.
mrwibble
posted on 8/7/10 at 03:06 PM Reply With Quote
from what i've seen from underneath, i have a feeling it will be the rocker cover gasket which has always looked dodgey to me, or its actually become porous itself... will have another look soon, but i wonder how much a new sump would be... thanks for all replies
[Edited on 8/7/10 by mrwibble]
