contaminated
| posted on 14/7/10 at 09:51 AM |
Fuel Issue on right hand turns!
Can anyone shed some light?
Last year I did a bit of a re-furb, including my Weber 45s. Car has since been stup on an RR - everything is generally fine.
I've noticed that when I fling the car round tight right handers (and roundabouts) the car splutters and runs rough for several seconds
afterwards.
I'm absolutely sure it's a fuel issue. My first thought was fuel starvation, but:
1. The symptoms are more like flooding and sometimes (if I stop immediately and investigate) I'll get a bit of black smoke
2. It has a regulator and decent fuel pump
3. The pick up from the fuel tank is on the passenger side
Any ideas? It only lasts a few seconds and it's only on right hand turns. 2 litre Zetec on 45s, megajolt, filter king regulator and solid state
fuel pump.
many thanks
Dan
Tiger Super Six Independent
www.southernkitcars.com
pewe
| posted on 14/7/10 at 10:00 AM |
Dan, similar prob. on my set-up improved (but not totally cured) by fitting a larger float chamber needle valve. This improves the refresh rate in the
fuel chamber.
Difficulty of course is in deciding whether the problem is over- or under-fuelling since it happens for only such a brief period. Needle valves are
rel. cheap though.
Northampton Motorsport should be able to sell you the necessary and are normally generous with their advice.
HTH.
Cheers, Pewe
jossey
| posted on 14/7/10 at 10:13 AM |
only turn left! sorted :O)
ok maybe not helpful but its the best advise i have.
:O)
dave j
contaminated
| posted on 14/7/10 at 10:30 AM |
fuel chamber.
rel. cheap though.
HTH.
Cheers, Pewe
Good suggestion although the car did it before and after the carbs were setup by Gerald Dale - so I would assume the needle valves are ok.
RichardK
| posted on 14/7/10 at 12:37 PM |
brim the tank with fuel and try again, do you have a swirl pot on the fuel tank?
Rich
Gallery updated 11/01/2011
contaminated
| posted on 14/7/10 at 01:16 PM |
quote: do you have a swirl pot on the fuel tank?
No. Do many people running carbs need one?
cliftyhanger
| posted on 14/7/10 at 03:38 PM |
no swirl pot will be needed with carbs. The float chamber will run them for minute or two with the fuel pump off.
The problem as you have pointed out is over-fuelling. Solution.....I am going EFI!
The Des Hammill weber book has a "fix" for the problem, but involves fitting an overflow to the float chambers to stop them over-filling.
However there is bound to be another fix somewhere, it does seem a common problem.
Bigheppy
| posted on 14/7/10 at 05:10 PM |
Oil surge ? Just a thought oil splashing about being forced through the crankcase breather and sucked into the inlet.
Hugh_
| posted on 14/7/10 at 07:46 PM |
Dan's crank case breather goes to a catch tank.
RoadkillUK
| posted on 14/7/10 at 08:45 PM |
I had a similar problem where my car would cut out on roundabouts mostly but also other right turns.
As it turned out, it was the ignition switch on the back of the barrel, I bypassed it for a couple of weeks (hotwired it) and then replaced the
switch, since then all has been well.
HTH
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
