Author: Subject: Remote gear lever 4 speed Help
greed1
posted on 16/7/10 at 12:02 PM Reply With Quote
Hi
I am looking for a remote gear lever for a mk2 escort 4 speed box but haven't found anything yet does anyone sell these if not is it possible to make one
It is right inthe way of the dashboard ATM
Help greatly appreciated
Thanks Graham
Drive it stright sideways
thunderace
posted on 16/7/10 at 12:12 PM Reply With Quote
i dont think you can buy one
what 4 speed box do you have type 3 ?
http://www.zetecinside.com/xr2/gearbox.shtml
[Edited on 16/7/10 by thunderace]
It's not too hard - it involves cutting the existing gearstick down to a few inches, then connecting it with a metal bar to a new gearstick further back. The new lever uses a rose joint to allow it to swivel.
Hard to explain, but easy in pictures! If no-one else posts a picture then I'll look through my archives tonight.
The only down-side is that you lose the 'push-down' function that stops you going into reverse. There are ways round that though.
posted on 16/7/10 at 12:18 PM Reply With Quote
Update
Previous thread
Pictures halfway down - you can make it as simple or as complicated as you want...
wicket
posted on 16/7/10 at 01:46 PM Reply With Quote
Look at mine here, a bit agricultural but it works a treat
http://www.locostbuilders.co.uk/viewthread.php?tid=49786
greed1
posted on 16/7/10 at 03:37 PM Reply With Quote
Thanks for all the links I couldn't find anything in the search I have a type 2 by the looks of it
Wicket yours looks great im going to try and keep it simple like in David's link
Went to the black smiths and got the metal bits just need a rose joint as well and a welder now
I will post some pics when I get round to it and the rain stops
Thanks again graham
greed1
posted on 16/7/10 at 06:05 PM Reply With Quote
Would an 8mm Rose joint be strong enough
worked out were it should all fit together just need a few bits
[Edited on 16/7/10 by greed1]
wicket
posted on 17/7/10 at 10:04 AM Reply With Quote
8mm rose joint works fine on mine
