madteg
| posted on 19/7/10 at 07:11 PM |
megasquirt help
Have got interference from somewhere, my throttle enrichments ars spiking all the time. Have had a look and found that my power to ecu shares the same
circuit as the feed to the coil . Also my loom from the wideband goes under the coil is this ok.
flak monkey
| posted on 19/7/10 at 07:14 PM |
Are you sure its not just the threshold set too low?
Sera
http://www.motosera.com
RichardK
| posted on 19/7/10 at 07:18 PM |
You using sheilded cable grounded only at one end?
Rich
Gallery updated 11/01/2011
rf900rush
| posted on 19/7/10 at 07:21 PM |
I would not use the feed to the coil for your MS.
A seperate fused feed (ignition switched) wolud be best.
Have good look HERE if you have not allready done so.
Martin
madteg
| posted on 19/7/10 at 08:00 PM |
set the threshold at 20.00 and it still did the same so i know its not that, have been trying to map car for two years, have got it close but not
quite there because on cruise it jumps between 14 and 16 i do believe this is the problem.
