Author: Subject: Heat proof barrier
dhutch
posted on 22/7/10 at 12:10 PM Reply With Quote
Heat proof barrier
Where my exhaust passed by the bodywork it gets hot, in this weather, too hot to touch. And its trying to decolour!
What sort of thermal barrier would people use, the exhaust is wraped, but the heat that pours of it is still huge.
Ebay seems to do fibrous silvered sheet (6inch strips only) like this
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=330417570944&ssPageName=ADME:B:WNASIF:GB:1123
Or corrugated foil sheets for similar cash.
http://cgi.ebay.co.uk/HEAT-SHIELD-HEAT-BARRIER-G1-LITE-MATERIAL-3-6mm_W0QQitemZ170501836339QQcategoryZ38786QQcmdZViewItemQQ_trksidZp4340.m263QQ_trkpar msZalgo%3DDLSL%252BSIC%26its%3DI%26itu%3DUCI%252BIA%252BUA%252BIEW%252BFICS%252BUFI%26otn%3D8%26pmod%3D170458158161%252B170458158161%26po%3D%26ps%3D63 %26clkid%3D6944533158748952524
Also, how would then be best to stick it to the back of fibreglass, which is currently also rather oilly!
Daniel
adithorp
posted on 22/7/10 at 12:29 PM Reply With Quote
I'll assume you mean under the bonnet if you want to put it on the inside.
CBS do "heat mat" by the metre from a roll and as high temp adhesive to fix it. Just degrease the grp first.
You might want to put some vents in to let the hot air escape as well instead of just sitting there.
adrian
http://jpsc.org.uk/forum/
speedyxjs
posted on 22/7/10 at 12:54 PM Reply With Quote
Iv put four layers of exhaust wrap on mine.
scoop
posted on 22/7/10 at 03:03 PM Reply With Quote
The wrap should be enough. Have you checked your timing recently and its not too advanced making the exhaust too hot?
dhutch
posted on 22/7/10 at 03:10 PM Reply With Quote
Its possible. The state of tune of the enigine is as i got it, which may well be well up the swany!
ali f27
posted on 22/7/10 at 03:33 PM Reply With Quote
Hi guys go and get soldering mat b/q works on mine and costs pennies
matt_gsxr
posted on 22/7/10 at 10:32 PM Reply With Quote
Doesn't retarding the ignition cause this problem. I.e. when the ignition is late the exhaust gases are still burning as they leave the engine, and haven't given up their energy to the piston?
Happy to be corrected, if you are sure
Matt
scoop
posted on 23/7/10 at 12:31 PM Reply With Quote
One extreme to the other yes. But, worth checking none the less
