-matt
| posted on 23/7/10 at 11:08 PM |
MT75 oil leaking
just taken the MT75 off my donor sierra, and have noticed red oil dripping off the bottom?
is it likely this is just the seal on the drain plug, or will the internal oil seals have probably gone?
would it be best to get it refurbed? (is it easy/possible to it myself?) or just get another off ebay and hope its a good one?
it will be going onto a zetec if that makes any difference.
cheers
big_wasa
| posted on 24/7/10 at 06:51 AM |
there is a breather plug that it will leak from it you tip it on its side.
There is also a gasket around the reverse switch that I would check..
