madteg
| posted on 25/7/10 at 04:13 PM |
Zetec camshaft oil leak
I have a small oil leak from front of the inlet cam around the seal i think. Have put new cam seal in and new camcover gasket but still leaking, any
ideas thanks
[Edited on 25/7/10 by madteg]
SeaBass
| posted on 25/7/10 at 05:11 PM |
Not sure but could be down to breather filter blocking up/crankcase pressurisation?
JC
JAMSTER
| posted on 25/7/10 at 05:39 PM |
have you had the cams out if so it could be leaking from under the end cam carrier cap a small amount of sealer under the cap may sort it
[Edited on 25/7/10 by JAMSTER]
| posted on 25/7/10 at 07:04 PM |
Pressure build up in the crankcase due to high boost?
madteg
| posted on 25/7/10 at 07:13 PM |
Had cams out didnt put any sealer on cam caps, will try it now, thanks
JAMSTER
| posted on 26/7/10 at 12:42 PM |
only do the front caps small amount mind the oil way
