black.viper
| posted on 26/7/10 at 07:58 AM |
Help with resetup Pinto Vernier pulley
Hi mates, I would like ask for help with this vernier pulley:
I tried resetup it but without success .-( I couldn´t turn with this although I loosen all screw!!! I dont know how much I could use the power - I
tried help a littel wiht screw driver like crowbar... but wihout effect - belt is down when I manipulated with this...
Questions:
1. Are you have belt down with resetup it?
2. How much power you must use for resetup it?
3. Any idea what I could do with it?
Thank you very much for any answer.
Regards,
Petr
Im building Tiger Cat E1 Duratec engine
mookaloid
| posted on 26/7/10 at 09:00 AM |
burton power cam fitting instructions page
Edited to add: you do realise that you need to turn the camshaft for fine tuning once the pulleys etc are in the correct place?
[Edited on 26/7/10 by mookaloid]
omega0684
| posted on 26/7/10 at 10:45 AM |
^^^^ tells you everything you need to know!
black.viper
| posted on 26/7/10 at 03:45 PM |
Ok thanks... sorry for my english but the problem is elsewhere...
Engine is running good. Timing is due camshaft (FR33) - but I have problem that I could turn with pulley parts among themselves with (blue parts
agains black) ...
I released all bolts but withou effect ... I try use row power but without effect... I dont know how much rgross I could use...or if is there some
trick .-)
Thank you for patient .-) with me.
mcerd1
| posted on 26/7/10 at 04:06 PM |
will it come apart if you take the bolts out completly ?
black.viper
| posted on 26/7/10 at 08:35 PM |
No, I did it ...but not happened... all bolts were out, I tired turn parts among togeather but withou success .-(
