Jasongray5
| posted on 29/7/10 at 04:13 PM |
Leaky zetec sump gasket
Hi guys,
Finished shortening sump and so forth, putting my engine back together i replaced the sump gasket between the block and the ali part of the sump. I
over filled the engine with oil to keep it fresh/check for leaks and there is oil coming from between the ali part of the sump, and the block, when I
tilt the engine forward, and back, it gets worse. I used the burton sump gasket if that makes a difference. Also, it stops doing it when oil is at a
normal level?
Is this normal, or do I need to use the original ford sump gasket.
(its a blacktop with the 2 part sump... I also replaced the rear crank seal and the gunge between the steel and ali parts of the sump. All of this is
not leaking)
Any idea's/help greatly recieved, Jason
How hard can it be?
http://www.flickr.com/photos/33261515@N03/sets/72157611049241239/
SeaBass
| posted on 29/7/10 at 04:58 PM |
Did the old gasket use the ford spec RTV sealant like on the joint between the alumnium and steel parts of the sump?
JC
Jasongray5
| posted on 30/7/10 at 07:41 AM |
No it didnt
How hard can it be?
