Author: Subject: Where can I get smaller balls? (Lobro)
v8kid
posted on 5/8/10 at 03:20 PM Reply With Quote
I'd like to have a go at lightening my CV's but where do I get undersized balls?
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
Miks15
posted on 5/8/10 at 03:21 PM Reply With Quote
jump in cold water? seems to do the trick nicely
(someone had to say it)
posted on 5/8/10 at 03:42 PM Reply With Quote
Thailand? Allegedly there are plenty of lady-boys there with just your request...
Will you be reducing/cutting the sockets yourself? I'm impressed!!!
v8kid
posted on 5/8/10 at 03:55 PM Reply With Quote
Oh is turning the carriers down difficult?
I was hoping to grip them on the inner diameter with a 3 jaw chuck on a lath and turn them down with a standard carbide tipped tool. Never crossed my mind they might be hard all the way through.
Find out shortly I suppose - if I can get smaller balls that is!
flak monkey
posted on 5/8/10 at 04:14 PM Reply With Quote
You will get a considerable amount of runout if holding it in a 3 jaw and they will be hard.
Carbide tools wont touch hardened steel, you need ceramic or CBN tools for machining it...
Balls are available from most good industrial bearing stockists.
Sera
http://www.motosera.com
Richard Quinn
posted on 5/8/10 at 04:15 PM Reply With Quote
Can be done. Just take some of the unnecessary meat out of the carriers and then you don't have to worry about your balls...
Have a look here scroll down the page and you'll see lightweight Lobros
v8kid
posted on 5/8/10 at 04:52 PM Reply With Quote
Ah exchange! So for £40 someone else will do it. Seems reasonable but it can't be that difficult if they are so cheap after all the seller has to make a living.
Flak see your point if its really hard material but should not be any runout if properly mounted in a 3 jaw chuck - I've just finished machining some spiggot rings using a similar method with no probs and the measured runout was less than a thou ( thats all my dial gauge measures to)
Are the originals to a high tolerance perhaps?
Edit. Just realised 4 sets at £40 is £160 so I think I'll persist!
[Edited on 5-8-10 by v8kid]
SteveWalker
posted on 5/8/10 at 06:58 PM Reply With Quote
For accurate stuff I forget the 3-jaw, using collets for small items and a DTI to centre larger items in the 4-jaw independent.
SteveW
flak monkey
posted on 7/8/10 at 06:18 PM Reply With Quote
Youll get zero runout on anything machined ina 3 jaw if its all machined in the same setting, but you will be holding on a premachined diameter and modifying another and you will get a reasonable level of run out with a 3 jaw. Maybe as much as 0.05mm if the chuck is in good condition, if the jaws are worn then expect double that. You can get things to within 0.01 or better in a 4 jaw.
I think the ones in the link are £40 per pair not each.
Sera
v8kid
posted on 7/8/10 at 09:06 PM Reply With Quote
Hey flak I'm a rough old engineer and 2 thou is OK by me when it's not that important!!
My machinist pal tells me I'll cut anything but HSS if the speed is fast enough and the cut is fine enough. Tried it last night on a gash toughened drive flange and it scared the bejusus out of me. Cut it though and the carbide tip is still sharp.
The old lathe shook about a bit though and I expected the cut to be like a 50p piece but all was OK.
Take your point it's only £80 not £160. Itmight be worth spending the time on stuff that would give a better return - like redesigning the front uprights for the umpteenth time!
PS Can someone without being a smart **** tell me where I can get under size balls?
